robharvey wrote:
Jamie, I for one would be very interested in seeing this information. Please post what you have. Also, if trailers have to be inspected, where do you go (the same places you get NC inspection on your car?)?
The book you get when you goto inspection class at wake tech.
NCDOT DMV Enforcement Section, Safety Inspection, Emissions Inspection, Windshield Certificate replacement, Regulations Handbook
Page 71
Additional Lightin Requirements
Section 4.
On every trailer or semi trailer having a gross weight in excess of 4,000 pounds:
(a) On the front, two clearance lamps, one at each side.
(b) On each side, two maker lamps, one at or near the front and one at or near the rear
(c) On each side, two reflectors, one at or near the front and at or near the rear
(d) on the rear, two clearance lamps, one at each side; Also two relectors, one at each side, and one stop lamp
Section 6.
On every trailer, semi trailer or pole trailer weighing 4,000 pounds gross or less:
(a) On the rear, two reflectors, one on each side. If any trailer or semi trailer is so loaded or is of such dimensions as to obscure the stop light on the towing vehicle, then such vehicle shall also be equipped with one stop lamp.
(b) Front clearing lamps and those marker lamps and reflectors mounted on the front or on the side near the front of a vhicle shall display or reflect and amber in color.
(c) rear clearance lamps and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
As I look through the book again I cant pinpoint where it says trailers over 4500 gvwr needs to be inspected. It says trailers need to be inspected but doesn't give the weight cutout. The section on lighting makes it seem like, if it comes with lighting, a safety inspection is required to make sure it operates if over a certian weight. The only absolute answer I can give you is call the dmv, which is never fun. Lettme look through some other books.
edit: as George Bright said, anywhere that does inspections can do it, they just need that sticker. A motorcycle shop or trailer store is the best bet (same sticker).
