Donnie Barnes wrote:
Oh, oh oh!
If you're putting in that black 4" drainage pipe, be careful! In my recent experience, much of what is out there is crap. It'll get compacted quite easily if there is *any* traffic over it, even if buried 12" or more. Shop wisely.
No problems with the stuff Lowe's sells. Lasted 12+ years until we sold the house. Never clogged. Buried about 12" to the bottom of the trench, depending on the pitch required. Couple of places in the yard, I had to go maybe 18" deep. I also connected 3 of my neighbor's gutter spouts which were spilling into my yard and actually contributing much of the surface water!
Another note: If you're gonna dig trenches in the yard: 1.) Get a TRENCHING SHOVEL. 2.) Have the "Call before you dig" guys come out and locate every electrical, gas, water, phone, cable line in the yard. They do it for free, and will save you lots of problems. 3.) Don't even consider "French Drains" or "Dry Wells" to accomodate the water. They're useless and a waste of time and money. 4.) Depending on where you live, it's probably not advisable to break through the street curbing to terminate your drainage. Cary frowns on that, and I suspect other cities won't allow it either.
Dustin: I used pretty heavy clear (opaque) polyethylene sheeting to line the crawlspace, but it came on a roll, as I recall, then it unfolded to about 12 feet wide. Depending on how often you'll be crawling around under the house fixin' stuff, anything fairly durable should be fine.
