I seem to have my share of questions lately.
I have shredded several trailer tires in recent history. I keep them aired up between events, but I guess now and then I cut a tire while driving. The air goes down while I'm traveling at highway speeds and the first indication that I get something is wrong is that I'm seeing debris flying behind my car in the rear view mirror. About the time I realize that its my trailer tire flying apart, I hear an awful flapping noise and get the bright idea to slow down and check things over. Usually by then, the tire is totally destroyed.
I could purchase a $200 to $300 tire monitoring system, which seems a little silly on a utility trailer. My trailer rims are 14" rims and lately I've just been running car tires. The load is only a few hundred pounds on each tire, well under the tire load rating.
I'm wondering if it would help to install inner tubes in the tires. I know that radial tires don't require inner tubes, but I'm thinking that they might help maintain pressure better than not running tubes. I've heard from others that you should never run an inner tube in a radial tire. I've also seen in writing in places that it is ok to install an inner tube in a radial tire if it was rated for a radial tire. In fact, I saw some today in a store that are rated for radial tires, or so the box says.
Can anyone tell me if there is a real safety issue with running inner tubes in radial tires? I know some rallycross folks have done it to help maintain pressure in the tires in case you momentarily crack a bead. I'm having a hard time imagining that this inner tube in my trailer tire is going to create a big problem.. but I thought I'd ask the gurus here first.
I dug around on the web for awhile, but I couldn't really find any articles that helped me with this issue.
Thanks!
Miles
