michaelsmiller wrote:
Corn is a fuel like anything else. It has only shown to be a problem with certain materials. These materials were phased out long before your 2002 Honda was built. The other down side of ethanol is that it does not have the shelf life of pure gasolene. I ran my Mazdaspeed 3 on E15 when I was out west last summer. Being a turbo car, it seemed to run much better. E15 premium was cheaper than regular. That being said, the use of ethanol has to go up in cars. I have read articles and they seem logical, that octane ratings have to go up in order to allow our internal combustion engine's efficiency to improve. Because of turbo's and direct injection high compression engines, many more cars today require premium than in the past. That's why the price of premium has gone up so much in the last few years. I've heard it said that 98 octane may be the fuel of the future. Water in gas is not a detriment either. It assures a controlled flame front and helps reduce combustion chamber hot spots. I worked on water injection systems for turbocharged engines in 1976 whiles in college. BTW, what fuel does NASCAR run? Yes, it's E15 98 octane pump gas, not racing fuel. For once in a long while NASCAR may be a technology early adopter.
My wee 1.0L runs 10:1 compression and up to 17.5 PSI on 87 Octane just fine. That said, I do run 93 in it because it seems to run a bit smoother. I think on 87 I can feel it pull timing to keep knock in check where with 93 it's able to pretty much allow full timing so I don't get the surge from it pulling and adding timing. This is purely from the butt dyno though, I don't mind the extra money since I average about 40mpg back and forth to work
