Richard Casto wrote:
Volvo V70 (V70R?) - Bigger car, but maybe interesting if you get a fixer upper V70R?
Stay away from the V70R...having owned two of them, bought new, 2004 and then a 2005 that Volvo swapped us into since the 04 was about to be lemoned. The 2005 was a 6MT some here might remember, and by the time it had 16k miles on it, it too showed many of the issues the 04 one had such as failed rear wheel bearing, front axle splines play issue, etc, but the worst thing about these cars (P2 V70R/S60R) is that the rear suspension is an awful design. It has too much toe-in on compression, so when you hit large one-side bumps, you get rear end bump steer -- it's simply awful. Volvo came out with stiffer rear bushings to "fix" the problem, and we had that "fix" done on our 2nd one, but it didn't do anything. After driving the Pennsylvania turnpike in late 2005 and continually dealing with scary rear bump steer, I sold the car right away (at that point, 11 months into ownership, it had over 10 warranty visits some with multiple claims like the driver's side heat failing, exhaust deflecting into driveshaft during heavy rain, etc, etc).
All that said, for a stock wagon the 6MT was fun. With Corsa R-comps, PFC01 pads in the stock Brembo calipers, and a decent alignment, I was able to turn 1:24-1:25 on South course without too much trouble.
