 Post subject: caddy giesel with duramax bench race
PostPosted: Wed Nov 12, 2014 11:23 pm
if you take the caddy giesel body.and put the duramax and allison tranny in one.build as a street rod,that thing would be a sick sleeper.350-400 hp and 650 ft lbs torque stock,then turn up the fuel,and turbo adn stuff.600 hp and maybe 1000 ft lbs,in 4 k lbs, that would be absolutely sick,and not out of hte question.
 Post subject: Re: caddy giesel with duramax bench race
PostPosted: Thu Nov 13, 2014 12:04 am
Low red line will be a problem. It will be shifting as much as accelerating.
2005 GMC Sierra
1991 318is Garage Ornament
PostPosted: Thu Nov 13, 2014 10:43 am
The duramax turns 4500 rpm.Four valve head,pushrod of course.NHRDA dot com,13 second street diesels.8k lbs and runs 13 in quarter mile.The record is mid 6s at 216 mph for a diesel powered rail,powerglide with overdrive.scheid has one that has a cummins..Hypermax diesel has a rail,with a dt466 international harvester diesel 6.Big mutha with triple turbos and nos.The rail weighs 3k lbs..1k lbs is engine.
The late model 7,3l turbo diesel,has a intercooler ours does not..And builds 300 hp and 500 ft lbs torque.
PostPosted: Thu Nov 13, 2014 4:47 pm
https://www.youtube.com/watch?v=92VOUYSBiUQ
Chevelle with hot street duramax in her,high 11s at 120 mph quarter mile.You should watch how much that frame twists,under the 1k ft lbs torque.
