Well, OK its not a car, but I figured it’d be a good warm up project for a real the resto-mod I have planned. It has all the required elements:
Classic 60s model
Frame-off resto
Big engine swap
Big tires to put the power down
Pieces and parts from newer models
So we start with a 1968 JD110 Hydra-lift. (BTW, the Hydra-lift was a fairly rare option).
It’s powered by a single cylinder 8hp, Kohlar K181. It has a couple of issues. The K181 motor is pretty well used up. Very low compression, smokes, etc. and many parts are no longer available. The transaxle is another issue. Ever since I’ve owned it, it has refused to go into 1st gear. Engine running, engine stopped, clutch in, clutch out, rocking the tractor – it just would never go into 1st. I didn’t worry too much about it when I was mowing, but for tilling, I’d really like the granny gear.
Striped to the frame
Got the frame, dash and front axle cleaned, painted and reassembled. I rebuilt the steering column/box and replaced the ball joints on all the steering rods.
I progressed toward opening the case to find out why it won't go into first gear. I think I found good news - nothing broken. It appears someone has been in here before and reassembled it incorrectly.
When I shift it to 1st, it is looking for a gear at the location where the pen is pointing - obviously there is no gear there - just a spacer.
Bingo! I swapped the two gears so the big one is on the bottom and shazam, works perfectly.
Got the tranny put back together with new seals and bearings - and new brake pulley.
Next is the big engine swap. We'll be going with an 18hp, V-twin.
The bigger motor means we need to move the hydraulic pump, fuel tank and battery. Here's the stock setup: the pump is on top of the motor, the 1gal gas tank is between the motor and the console and the battery is inside the console.
We get a 4gal under-seat tank and fender pan from an 80s JD212; modify our frame a bit, weld on some brackets and boom - fits perfect.
We modify the console, fabricate some brackets and boom - hydraulic pump has a new home.
The smaller gel battery sits in a new box behind the dash.
Trim the hood support to fit around the engine:
Test fit the hood and grille with new headlights:
Paint the engine and test fit some big-ass wheels:
Paint the fender pan and mount the remote oil filter:
Button it up, put wheels on it and take it out for a test drive!
Man that was fun! This thing makes me grin every time I ride it.
