Post new topic Reply to topic  [ 60 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Dragged another basketcase home
PostPosted: Tue Apr 08, 2014 2:15 am
Not sure what my problem is with red 1980's vehicles these days. Bought a 1985 Porsche 944 with a 1995 Camaro 5.7L V8 LT1 (mostly) installed in it tonight:
This is an interesting situation because (1) I have always wanted a 944, call it an item on my automotive bucket list. (2) I have for some time wanted to do a completely inappropriate swap of a 'murican V8 into something that was never designed for it. Never having owned a 944 or anything with a SBC I find I'm on a new learning curve, which is fun.
Now I haven't even pulled the car off the trailer yet but here's what I can tell you:
- It's a 85 1/2 model with the updated dash and control arms
- 1995 LT1 with a "good" kit and parts and stuff but uses the stock 944 transaxle
- Still fuel injected, but unsure about ECU and wiring (I think the PO used a good kit)
- Was running fine 3 years ago when the PO pulled the heads to upgrade them
- PO plans changed and the car has been sitting with heads in the trunk for 3 years
- Bottom end looks OK but has some pitting on cylinder walls from rust
Goal is ... just a fun driver with track potential, without putting a dent in the wallet. So what do I do? Clean up the block, bolt the engine together, and see what happens? Or take the opportunity to do some upgrades? What kind of work should I be thinking of?
SBC knowledge is welcomed :)
 Post subject: Re: Dragged another basketcase home
PostPosted: Tue Apr 08, 2014 7:55 am
I have notified the authorities. Your Porsche Club membership is being revoked as I type this for buying an outlaw abomination! :soap:
Seriously, it looks like a great project. There will always be purist who will turn their noses up, but engine swaps in the 914 community are common (Subaru is popular), and I suspect it is the same way in the 944 community given some of the cost issues on the stock 944 motor, so my tribe approves. :thumbsup:
I am not a SBC expert by far, but depending upon how bad the cylinder look, I would likely bolt it up, get it running and then see what you think needs fixing. It might be plenty fun as is.
Richard
PostPosted: Tue Apr 08, 2014 8:38 am
Inspection criteria for registration? Since the engine is 1995 it looks like visual only for the emissions equipment so I guess you need to make it look like it has whatever the engine had in the donor car and be able to convince an honest inspector. Assuming NC car did the PO formally turn in the plates so you don't have any overdue registration and penalties for missed inspections?
Sounds like a fun project. Have you researched what it will take to keep the transaxle healthy?
PostPosted: Tue Apr 08, 2014 8:45 am
Did 944's come with the same transaxle as 928's?
PostPosted: Tue Apr 08, 2014 11:05 am
Put the heads on, get the engine running and flip the thing right away! :D
PostPosted: Tue Apr 08, 2014 11:07 am
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/521068-928-transaxle-into-944-951-a.html
PostPosted: Tue Apr 08, 2014 3:42 pm
Get the heads CNC ported while they are off if it hasn't been done already and a nice set of long tube headers if that hasn't been done already. Other than that, just bolt it back together and see if it runs. Do not tear into the engine unless you have to as the LT1 is the bastard child of the SBC world and parts can get surprisingly expensive.
PostPosted: Tue Apr 08, 2014 5:46 pm
Stock up on accessory belts.
PostPosted: Tue Apr 08, 2014 6:31 pm
Saw that thing on CL and thought it looked like a really good deal for someone looking for a V8 P-car.
There's also a V8 914 for cheap on CL that looks like it might be a hoot.
PostPosted: Tue Apr 08, 2014 6:41 pm
well, provide the link so mike can buy it
PostPosted: Tue Apr 08, 2014 7:36 pm
Stock up on ignition modules and the opti-spark (the distributor under the water pump). The Lt1 is the first sbc that uses a reverse flow head, so only lt1 heads can be used on it. A good tune will amaze you, I recommend Carolina Auto Masters. Jeff tuned the Lemons Trans Am we drove and got 275whp, the stock lt1 is rated at 275hp at the crank.
2004 C5(415whp,390ft/lbs),
1997C5,1997Trans Am, 1986 C4,
PostPosted: Tue Apr 08, 2014 10:00 pm
The LT1 can be rather finickey. Bob Kendrick has a bored and stroked LT1 at 396 cid in his jeep cherokee. On the track cooling is an issue. It will die from overheating faster than a Honda. BTW Bob has all the emissions stuff on his motor. His 94 vintage motor has cats, electric air injection pump, EGR, charcoal canister, and pcv system. The EGR and air injection are not programmed to work. He is using a reprogrammed OEM ECU from a Road Monster. Carolina Auto Masters has done most of the tuning.
PostPosted: Wed Apr 09, 2014 2:27 am
@Les - I'm thinking about just taking the heads to George at CHS and say "work some magic" within a reasonable budget. I'm pretty confident he doesn't do any CNC work ... what's the CNC port entail, and does anyone do it around here?
@Bret - I'm quite happy with the deal I got, considering I didn't pay his asking price :)
Jigsaw puzzle! Bless the PO, he bagged and labelled all the engine pieces. Came with some nice Wilwood master cylinders too (which I don't plan to use). Heads look good too.
Spent a little time on one side with the buffer, paint's in ok shape, thin in a few spots. Couple of dents and spots with paint missing. If I end up falling in love with the car I'll probably have the fenders and front bumper resprayed. Seats are trashed, need to figure out what to do about that. Otherwise, cosmetically, it's pretty good. Straight, no evidence of big hits or lots of paint work, and rust-free.
PostPosted: Wed Apr 09, 2014 2:31 am
Here's a picture from the seller of what the engine bay looked like 3 years ago before he pulled it apart...
PostPosted: Wed Apr 09, 2014 10:04 pm
CNC porting requires a very large expensive machine, George cannot do it, but he might be able to point you to someone. George was really impressed with the CNC port work on my heads and they made real good power. Maybe theses guys? http://rpmmotorsportsnc.com/i-13995036- ... eads.html#
