Jordan Normark wrote:
Frank Catena wrote:
We've "closed" our crawl. Blowing insulation is probably first as a better bang for your buck and time.
But - before you do either, make sure you seal all the penetrations both in your attic floor and your crawl ceiling. This is important because of the stack effect and air filtering through your house. Insulation only meets its rated "R" value in still air. The cans of expanding foam sold by HD, etc. work fine for this. Be careful in the attic. Sheetrock doesn't support much weight - yep I had a ooops there so we started contracting a good part of this.
We followed this path:
- Sealed the floor/attic penetrations.
- Blow additional cellulose in attic to upgrade to R42 or so (an additional six inches in our case)
- Closed/conditioned our crawl - Removed R19 from underfloor. Closed cell spray foam on the walls to R14. Ground poly sealed to piers and walls. Provided one positive close air duct in the crawl space for dehumidification. No air return. Not technically "sealed" because we run a slight positive pressure but we followed the code. We have a remote temp/humidity display from our crawl so I can monitor things.
- Our most recent project was a couple of geothermal heat pumps this spring. They sure look pretty sitting it that clean white crawl space.
Frank
I have a couple of concerns about sealing the crawl. The first is draining any moisture, I probably need to wait a season or two to figure out if it gets wet down there. I dread the idea of trenching the perimeter and adding a French drain. I guess some things are worth hiring out
My other concern is the furnace combustion intake. I guess if you have a newer high efficiency unit, you can run your intake and exhaust with pvc pipe to outside. What should I do with an older furnace located in the crwal that intakes from the side of the unit? It's probably not the best idea for it to source intake air from a "sealed" crawlspace.
I would definitely make sure the ground is relatively dry first. Our builder installed a french drain around the perimeter and the dirt was pretty dry under the poly before we closed the crawl. The problem in NC is that the dew points in the summer are often around 70F overnight. In a vented crawl this outside air creates higher humidity and potential condensation in the relatively cool crawl space even without ground moisture.
It's also helpful to have a drain to the outside from your crawl space. Especially if your water heater is there.
Here's a good link to cover the issues with combustible appliances. The folks at Advanced Energy did much of the research around closed crawl spaces.
http://www.advancedenergy.org/portal/cr ... erence.pdfI'll note that my empirical measurements as well as research papers in Building Science indicate that relative humidity readings need to reach at least 85% before you run the risk of mold forming on framing limber. Plywood is even slightly more resistant. So, imho, no need to dehumidify to the 50-60% range as some (mostly dehumidifier manufacturers) claim.
We've been fine with an HVAC vent with a positive close damper off the crawl air handler.
Frank
