shawnwhipple wrote:
Does anyone have any suggestions on what works for them. Keep in mind I don't usually need to transmit for 20 miles just talk to folks that I'm traveling with in a caravan.
Back about 15 years ago when I was getting a CB I found out a few things. I'm no expert but here's what I learned.
The perfect antenna for the CB band is a stainless-steel 102" lg whip. ANYTHING else is a compromise. If you were to buy a 48" magnetic mount, 48" is in the mast and the remaining 54" of wire is wound inside the base. That's the way is was explained to me anyway.
I have a CB in my car (the Cavalier) and I store the magnetic mount antenna in the truck when not in use. It works well and was relatively cheap. The best magnetic mount is a K40 brand. However the original K40 has one helluva magnet. The thing must be 10" in diameter or something. Stick it on the roof of your car and it won't budge even at over 120 MPH. They have since made a K50 (I think that's the number) which is what I have. Much smaller (approx 4" diameter) magnet but works just fine.
Also the VSWR ratio will affect your range. It is adjusted by slight changes in length of the mast. A meter is used to measure the ratio. I have one (somewhere) if you'd like to borrow it. With a 4-watt radio the VSWR
does matter, trust me.
My advice on the subject is to stay away form those tiny (less than say 36") antennas. The VSWR ratio is probably like 5:1 or higher on those things, ask me how I know. Also get a decent radio like a Uniden XL (about $50 at a truck stop) that has a 4-pin mike.
