Post new topic Reply to topic  [ 115 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 Post subject: Re: VK's erection...with pictures!
PostPosted: Thu Sep 04, 2014 11:10 am
Do tell. What is the name of the VK Approved llc paint color?
PostPosted: Thu Sep 04, 2014 11:22 am
The Sherwin-Williams name is "Regal Blue".
PostPosted: Thu Sep 04, 2014 11:27 am
Steve, I'm betting there is no beer in that fridge.
PostPosted: Thu Sep 04, 2014 12:26 pm
Correct. Mostly Gatorade, some water, and a Coke or two.
PostPosted: Tue Sep 16, 2014 9:52 am
Here's a short photo essay of my latest shop project, a new cabinet to house paint's, oil, antifreeze etc.
First I put the cabinet on my yard cart and rolled it up to the house to give it a good pressure washing. Here it is, still wet behind the ears:
After it was clean I started the messy process of wet sanding the exterior with my DA sander and some 180 grit. Using water there is no dust, but it still makes a mess. After taking it back outside to wipe of all the sanding mess I rolled it back inside as seen here:
As you can see in the above pic, a few spots were down to the bare metal so I had to spot prime those areas to level the surface:
The metal shelf that came with the cabinet was bent and not very strong. I decided to replace with a 3/4" thick melamine-covered one which would be impervious to spills. To support the shelf I added two cleats:
The new shelf resting in it's place:
Next was hinges for the new doors. This cabinet originally had sliding doors, but I'm not a fan of those so I decided I build a pair to match my other cabinets.
I decided to use self-closing hinges this time, and of course it's never easy. I had to weld four tabs inside the cabinet to have places to attach the hinges. Yes, I could have simply welded the hinges in place, but there is a reason most hinges have adjustments, and that reason is doors can be a bitch to align. I left the adjustments, and I needed them! Here's tab #1 in place:
With the tabs in place, I drilled for the hinges and mounted them temporarily:
Using some 1"x2" Poplar and my Kreg jig for the pocket holes, I built two door frames. No need to have the complete the entire door assembly at this time as it's much easier to fit and align the frames alone. Door frame#1 is attached to the hinge:
With both door frames in place, partially open:
Now's when that hinge adjustment becomes necessary. To achieve a proper even gap I had to adjust both sides with shims, but in the end they line up really nice:
Since all the 'fitment' was done, it was time for some paint. I removed the door frames and hinges first, then wiped everything down before proceeding with the primer. After three coats it looked like this:
To get ready for the signature blue topcoat, I wet sanded the primer with 220 grit since primer is flat and pretty grainy feeling. After three coats of paint:
After it's dry I removed the masking:
I added the back panels to the doors and gave them three coats of paint:
Next I added the corrugated panel inserts to the doors:
Next I was finally ready to hang the cabinet doors. It took a while to get the hinges and spacing adjusted correctly, but once it was done, the doors fit really well.
All that was left after hanging the doors was fabricating the custom pull handles. I decided to use a cam gear from the old B21 parts car engine. The plan was to cut it in half and mount each half on a door so it would look like one piece when the doors are closed.
After I cut the gear in half, I cleaned up the sharp edges with a wire wheel and mocked it up on the doors. Here's where it stands with the doors and handles mocked up in place. I'm not sure why this pic came out so blurry.
Here's a close-up of the handles. Note I held the doors open slightly so you could see the two halves, but the door gap is really nice and tight with them fully closed as seen it the above pic.
It still need to paint the handle pieces tonight, but once that is done it should be ready to be put into service.
PostPosted: Tue Sep 16, 2014 12:09 pm
Nice workmanship and very creative!
09 Bullitt - DD
11 Fusion - Wife's DD
03 Mazda6 - Track car
00 PSD Excursion - Tow rig
61 F100 - Dad's truck
00 Cagiva - Adventure bike
00 DRZ400 - Woods bike
PostPosted: Wed Sep 17, 2014 6:24 am
Vk, I know you hate you some P-cars but check out this guy's garage.
https://www.youtube.com/watch?v=gC5-MoDUuRg
PostPosted: Wed Sep 17, 2014 8:23 am
Thanks Cash!
Everyone on 'Garage Journal Forum' is familiar with Jack Olsen and his garage. I like everything about it except that puke green paint color.
Oh, and I don't hate P-cars, but I would never own one because Hans.
PostPosted: Wed Sep 17, 2014 8:42 am
"Garage Journal" ??? Get da FUGH outta here!!!!!
PostPosted: Wed Sep 17, 2014 9:34 am
I'm pretty sure that everyone on the internet is familiar with that garage.
PostPosted: Wed Sep 17, 2014 10:44 am
Over 200,000 members so yes, it's quite popular. I don't think you'd make it more than a few days over there though. Mention politics, religion, or a personal insult to another member, and you'll get a quick trip to banned camp. The moderators don't mess around.
PostPosted: Wed Sep 17, 2014 10:56 am
I'm reformed. .. I swear. ..
PostPosted: Wed Sep 17, 2014 11:55 am
Maybe I have been in a hole, but I had never heard of that site before. I just signed up. It looks interesting!
I would love to have a showcase garage (and I like what you have done with yours VK), but my problem is that for the most part, mine appears to be a jumbled collection of rejects and lacks any type of "coherent style". Or the style might be described as a mix of Harbor Freight + Dumpster diving + oil and grease. And when I get something new (such as a number of nice, but clearly used storage cabinets), they go immediately into service vs. a new paint job, etc. first. My #1 enemy however is the use of the garage as "temporary" storage (in that temporary is never temporary).
It is not quite a "garage" but Adam Savage's (Mythbusters) personal workspace is quite impressive...
https://www.youtube.com/watch?v=l9AqYaSRjw0
Richard
PostPosted: Wed Sep 17, 2014 1:16 pm
Mine is far from a showcase and it's more of a work shop than a garage IMO. There are quite a few garages on GJ that I'd be scared to use a grinder or a can of spray paint inside for fear of getting it dirty. Mine's not like that at all. I try to keep it swept most of the time, and the tools picked up, but otherwise I'll cut, grind, sand, weld, paint, whatever inside mine.
The cabinet I just finished I've had for over two years, but just got around to painting it. The same with the drill press and bench grinder. Both were old and had been use for years, but I had a wild hair and wanted to try some painting so those looked like an easy way to start.
I run into some of that as well, but not too much. None of my wife's stuff is allowed in my shop at all, and I don't own a single piece of lawn equipment.
I've seen that, and yes Adam's space is small, but he has LOTS of tools and other cool stuff.
PostPosted: Mon Oct 03, 2016 9:44 am
10-3-16 Update!
I finally got around to building a 8' x 16' lean-to off the back of the shop to keep the firewood out of the weather. Special thanks to Stephen and Ben for their help with the project.
Here are the pics:
Image[/QUOTE]
