DickRasmussen wrote:
The "close the vents" (actually "seal the vents") is legit. A heavy duty study was done in Eastern NC that proved it is better. In our climate it is so humid outside in most of the summer that the vents are not going to lower crawl space humidity.
We spent "big bucks" to get a "fancy" system from these guys, including a dehumidfier and sump pump, and are very pleased with it.
http://www.basementsystems.com/basement ... ofing.html. We needed something that would allow the crawl space which is relatively tall in some areas to serve as a "dry basement storage area".
If you do the do-it-yourself approach you need to tape the seams really well.Dick
Actually no tape required, just need to have a 12" overlap. As to Matt's point, yes, it needs to be pinned or staked down so it wont slide when you walk on it.
I have done this on both of my houses (current and previous) and it works wonders. The before after difference is amazing.
I have not heard of pinning or staking, but then again mine is mostly level and it does not move at all when I walk upon it. I can see if you have a significant change in elevation (more than a few feet) that something might need to be done.
I do think you should to lay down a double layer on high traffic area such as the entry way. My crawl space is large enough that I can use it for storage, so the extra layer helps prevent against accidental puncture. Regarding taping, I think it should absolutely be done in addition to overlap. Maybe that is why mine doesn't slide around. Taping the seams is very easy to do. Lowes/Home Depot WILL have 6mil plastic plus tape for this. I think that same tape is used when they wrap and seal Tyvek on houses. You should also seal/connect (using using some type of caulk, nail strip, or combo) the plastic against the interior brick/block walls as well. All of this is an easy DIY project. It should only be hard if you have a very low crawlspace you say you are in the 3-4' range, so I expect it shouldn't be terrible.
If you Google this, you will find plenty of "how to". Years ago the idea was to leave the ground uncovered, or to put down plastic, but leave open areas to let the ground "breath". This is so much BS. All it does is allows moisture to exit the soil and most likely there is an unending supply in the ground, so it never really dries out.
