Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: Porsche Cayman S
PostPosted: Fri May 20, 2011 6:41 pm
RamVennam wrote:
Wow Ram, that is drop-dead gorgeous! Congrats. Those wheels look a lot like the 997 Turbo wheels, are they factory on the Design Edition?
Thanks guys. Yup. they are the Turbo wheels..standard on the PDE.
They're the same look, but aren't they narrower than the Turbo wheels?
My Blog
PostPosted: Fri May 20, 2011 6:54 pm
Yep, same look different widths. Those wheels come in 8, 8.5, 9.5, and 11 in widths.
PostPosted: Fri May 20, 2011 9:52 pm
be sure to drive it like you stole it Ram. otherwise it is wasted. ask me how i know. :twisted:
PostPosted: Fri May 20, 2011 11:25 pm
Will do! :thumbsup:
2004 Honda S2000
PostPosted: Sat May 21, 2011 10:50 pm
Ram, follow your heart. that way if the car breaks, you will want to fix it because you love it.
anyway, porsche built the 917 k30 can am car after all.i rather like the old 914 and the 924 S .
http://www.youtube.com/watch?v=zirXvjxXqzw
try this in a corvette and you would die. porsche in nurburgring in the winter.
PostPosted: Sat Jun 04, 2011 1:45 pm
Man that Cayman S is fun :). Ram and I just put ~100 miles on it and the revs rarely dropped below 4k......it's seen more 'use' in those 100miles than the 10k miles it had when he bought it ;).
PostPosted: Sun Jun 05, 2011 7:06 am
Got gas this morning...averaged 14mpg on that tank. We must have gotten like 10mpg during our 100 miles.
2004 Honda S2000
PostPosted: Mon Jul 11, 2011 9:43 pm
So I was reading on 6speedonline. Apparently the 09+ LSD equipped Cayman's differential is garbage. Matt Monson took it apart and there are 4 fiction disc plates in (2 on each side) the diff.
One would assume that this means there would be 3 instances of frictional interfaces on each side of the diff (2 on the outside and 1 between the two friction discs on each side). However, those geniuses in Stuttgart put the 2 fiction discs adjacent so there are only 2 frictional interfaces.
Not to mention there is no preload on it since it has no belville washers.
I would say that while it is not likely a Super Stock overdog, those that run them in SS are going to need new diffs yearly because soon as you get any wheel spin those friction pucks are going to be glowing red :)
http://www.6speedonline.com/forums/boxs ... ected.html
