http://www.autocar.co.uk/News/NewsArticle/AllCars/256560/The latest Toyota FT-86 concept at last month’s Geneva show is “95 per cent” the production car, according to insiders, accurate in its surfacing, although its 20-inch wheels won’t make production.
The FT has a monocoque structure, carefully engineered with high-strength steels to keep weight low. It is similar in length to an Auris at 4235mm and sits on a generous wheelbase of 2570mm, but it’s only 1270mm high – one good reason for its low centre of gravity.
Toyota is coy about the FT’s kerb weight, but if it truly undercuts the Scirocco by 200kg, it must weigh little more than 1100kg[=2425lb] ready to roll – a very impressive figure that rivals will want to investigate.
See Autocar's exclusive studio pics of the Toyota FT-86 II
The engine is basically a 2.0-litre, 16-valve flat four from the Subaru stable but with special modifications to suit this new application. Driving through a six-speed manual gearbox (or a six-speed paddle-shift auto in some markets), the unusual powertrain concentrates its masses considerably lower than an ordinary in-line layout would do, and further back in the car. A standard limited-slip differential further aids traction.
Toyota engineers say the engine produces around 200bhp, but final power, torque and fuel figures are still being derived because this Subaru-sourced engine uses a Toyota direct fuel injection system with Toyota’s own engine management.
Manufacturing begins in early 2012, on sale in Japan in mid-2012 and other markets soon after. They expect it will be around £25,000, which should translate to about $25,000 here.
