Chuck Branscomb wrote:
JamesShort wrote:
I'm trying to decide if this deal is worth jumping ship and giving 0w40 a go in the WRX. It's known to shear pretty quickly to a thick-ish 30 weight, but can it stay a thick-ish 30 weight for 3500 miles with 3-4 autocrosses like GC can
Have you seen oil analysis reports to support that claim (i.e. multiple reports)? There is a thread on the m5board where UOA are posted, and from the 0W40 users going 6-7k miles on a change, there is no significant viscosity problem noted. 0W40 has wonderful HTHS properties that other Mobil 1 oils are lacking fwiw.
I agree about the HTHS, and it's NOACK volatility is pretty low too (as are most ACEA A3 certified oils). However, 0w40 is a 13.4 cSt oil at 100 degC....about the thinnest 40 weight oil on the market. It's also renowned for shearing to a medium thick 30 weight (say 11.5-12.5 cSt). In fact during, the Q&A session with the XOM representatives on BITOG, XOM pulled a real BS response to the question about 0w40 shearing so easily to a 30 weight.
But yes, there are 100s of UOA of m1 0w40 shearing to 30 weights on BITOG. It's a great oil for someone like me who wants a robust and thick 30 weight with low NOACK volatily and high HTHS and ACEA A3 rating (ie not the run of the line energy conserving, almost 20 weight crap). However, for those requiring or wanting a true 40 weight, then it's probably not a great choice.
Granted, it is still a solid oil (the only M1 other than 5w30 ESP that I'd use in ANY car.....note the ESP...not regular 5w30 or Extended performance). 6-7 OCIs in a e39 v8 M5 without permanent shear into the 30 range is unbelieveable. Any UOAs to link?
EDIT: found this:
http://www.m5board.com/vbulletin/e39-m5 ... 0-uoa.html
And sure enough it was 11.6 cSt which is a mid range 30 weight. Let me say that it isn't necessarily a bad thing so long as you are aware of the fact that M1 0w40 shears a lot. However, if you are buying 0w40 because you NEED a 40 weight, then you should find something else.
