Karl Shultz wrote:
If you're stuck with the gears you don't like when you're racing the car, I would absolutely NOT change them. I'd drive with them every single event. It'll teach you how to better manage shifting in places you don't like. That's just me.
Karl has a very good point.
But if you do want to swap, I'd swap entire axle assemblies. How is it set up in your car? I'm assuming 4-link and disc brakes? If so, you're looking at removing the d-shaft, 4 link mount bolts (plus bolt for panhard bar if you have one), lower shock bolts, coil spring retainers (if you have them), and unbolting the brake calipers from the axle.
To make the swapping easier, you could build (or buy somewhere?) a mount for on top of a floor jack so that the pumpkin sits on it, and it also grabs the axle tubes.
I used to crew on a 4-cyl Mustang oval-track car, and we needed different rear gear ratios to be fastest at different tracks. We swapped whole axles. It was a little more trouble because we had drum brakes so had to bleed them each time. (We also swapped transmissions for different tracks to get different trans gear ratios, but that's a different story.)
91 RallyX Audi Coupe Quattro
89 A-Team Astro-van demo derby winner at 2011 NC State Fair (
http://www.youtube.com/watch?v=7MrZqwENRqU)
