 Post subject: Opinions wanted - 2010 Nissan 370z
PostPosted: Tue Jun 01, 2010 12:11 pm
Have a coworker looking to buy a weekend toy / occasional fun car. Track and autocross potential isn't really part of the equation right now, though I wouldn't rule out the possibility of an outing or 2 (how many of us got into this because we had a sporty car and wanted to use it). He currently drives a newish Acura TL but doesn't need the back seat practicality any longer.
The 2 cars he's strongly considering are the
1) 2010 370z with touring and sport packages
2) 2010/2011 Nismo 370z
His concerns are primarily quality and reliability, and less about all-out track performance.
Anybody have any experience or heard anything interesting on these cars?
 Post subject: Re: Opinions wanted - 2010 Nissan 370z
PostPosted: Tue Jun 01, 2010 12:20 pm
If he plans on doing more than 2 laps at VIR in either, a oil cooler add will be necessary. Other than that, I have heard good things from the people I know that bought 370z's with the sport package for autocross. - AB
PostPosted: Tue Jun 01, 2010 12:39 pm
make damn sure he upgrades the pads/fluid before hitting the track
http://www.caranddriver.com/features/10 ... ap-feature
PostPosted: Tue Jun 01, 2010 1:56 pm
Wow, Now maybe I know why a guy a the Alfa event in a Nissmo was so slow.
PostPosted: Tue Jun 01, 2010 4:16 pm
I think the Nizmo kit comes with an oil cooler.
PostPosted: Tue Jun 01, 2010 4:45 pm
If it isn't going onto the track, then it's kind of a wash. However,
Nissan's response is probably the best.
PostPosted: Tue Jun 01, 2010 5:06 pm
Interesting article. Sounds like OEM pads such, but the real problem is the need for cooling ducts for track use.
Lack of cooling = boiled fluid = no brakes = crash
PostPosted: Wed Jun 02, 2010 8:27 am
Unless he really likes the "G-nose" style body work on the Nismo... and the Nismo interior upgrades... the reviews I've read are that the suspension upgrades make it a less-than-ideal street car
I am in LOVE with the 370z ... 'specially they yeller ones :D
Stacy King
Midlife Crisis Participant
PostPosted: Wed Jun 02, 2010 3:54 pm
The C&D Crash seems to be a bit of a fluke. We have had many 350Z's and a few 370Z's and they do eat OEM rear pads, but no failures.
They are good cars. Could use a PS cooler though.
PostPosted: Wed Jun 02, 2010 5:00 pm
A bit ironic considering the 350 had a "track" edition. Interesting...
I guess the 350's have better air flow to the brakes.
PostPosted: Wed Jun 02, 2010 5:20 pm
Pseudo cautious/nervous guy
Nah, I'd say it's the brake pad compound as much as anything. The super soft, grabby, dusty OE compounds are to blame. They give such good brake feel for street driving, but they go out of their temp range QUICKLY. I'm guessing that the 370's pads are a bit of an extreme example - fast car, lots of clamping force, lots of rotor, and maybe an extra soft pad.
That C&D crash has been the topic of many discussions about this car, that's for sure.
Tom Freeman
Team Silver Bullets '91 240SX
PostPosted: Wed Jun 02, 2010 5:24 pm
I thought C&D went back with race pads and had the same result.
PostPosted: Wed Jun 02, 2010 5:27 pm
Yep, just looked at the article again. They retested with upgraded pads and fluid and had effectively the same result. Only a few good stops and the brakes disappeared.
PostPosted: Wed Jun 02, 2010 9:05 pm
FTA:
"And so we decided to conduct a test we hadn’t planned: swapping the Z’s standard brake fluid for an aftermarket product,  ATE Super Blue, which has a higher boiling point (536 degrees F). We tested the fluid, which goes for a little over $6 a pint versus about $5 for the stock fluid, along with a fresh set of brakes with the upgraded pads. Considering 23 essentially fade-free stops, not only did the fluid extend braking performance, but stops 24 through 31 showed gradual fade—a warning to the driver that things are starting to overheat—which made this by far the best setup. After that, even the ATE fluid couldn’t persevere, and it, too, boiled"
To say there was no improvement is not entirelyt accurate. There was a noticeable improvement after changing the pads and fluid. Perfect? Nope, not even close for me to want to buy one and put it on the track. Would be nice to see the results after adding some brake ducting to test their final statement:
"Our suspicion is that Nissan got a bit greedy in its quest for today’s all-important fuel-economy numbers and boosted the Z’s aerodynamics a little too far by cutting back on the amount of air directed through the wheel wells to cool the brakes. Key takeaway: If you intend to track a Z, don’t use the base pads, upgrade the brake fluid, and be sure to install brake-cooling ducts."
