<cont>
U.S.-spec Buick Regal being assembled alongside an Opel Insignia OPC Sports Tourer
The first boatload of U.S.-spec Regals arrived at the port of Newark, New Jersey last week and more are on their way in the coming weeks as GM prepares to start selling its new mid-size sedan in late May. The Russelsheim plant is scheduled to build about 26,000 Regals in calender 2010 with another 14,000 in 2011 before the Oshawa, Ontario assembly plant ramps up production and takes over.
Aside from the Buick grille and the inner details of the lamp modules, the Regal is virtually indistinguishable from the Insignia sedan, and that is a very good thing. Design manager Malcolm Ward explained that the team aimed to create a look that was muscular and sculpted while at the same time having very low aerodynamic drag. Depending on the body style, suspension and wheel/tire package, the Insignia's drag coefficient ranges from 0.25-0.30.
Since the Insignia was designed for the German market where triple digit autobahn speeds are not uncommon, low drag is not enough. Managing lift is also critical to maintaining stability at autobahn speeds. The rear deck has been shaped to keep lift to a minimum without having to resort to any extra spoilers, at least on the sedan. The European-only (for now at least!) five-door hatch does have a small lip spoiler thanks to its shorter deck.
The Regal's interior is also common with the Insignia but distinct from the LaCrosse. The LaCrosse gets a broad, flat dashboard with a floating gauge pod and center cluster. The Regal's design has more of a dual cockpit layout with a driver-oriented layout. Thus, the Regal has a cozier feel although its interior volume is comparable to the LaCrosse. The materials have a high quality feel and fit and finish was consistently excellent across all of the cars that we sampled.
One of our biggest complaints about the LaCrosse since day one has been its enormous A-pillars, which cause substantial blind spots. The Regal pillars are considerably slimmer and overall visibility is superior to the LaCrosse in all directions. According to Federico, the engineering team is working on slimmer pillars for the LaCrosse as well and we may see a running change next year.
The Regal has four inches less between its axles so the back seat isn't as commodious as the LaCrosse, but there is still plenty of room for two adults or three kids across the rear bench. The front seats are the same as those in the LaCrosse, which means they are very comfortable. However, the seats in the more sporting Regal are a bit wide and drivers may find them somewhat lacking in lateral support when they hit the twisty stuff.
All Regals will be mid-level CXL models with leather interiors for the duration of the 2011 model run. Next year the more performance-oriented GS and a base trim level will be added. The base models will get a new seat covering that combines a woven fabric center insert and protein-based vinyl covering for the side bolsters.
While European customers have access to a range of gas and diesel engines, North American customers will initially get two four-cylinder engines. When the first Regals arrive at dealerships in May, they will all be powered by the now familiar 2.4-liter direct-injected Ecotec inline four-cylinder with 182 horsepower and 172 pound-feet of torque. This 2.4-liter will be paired with the same 6T45 six-speed automatic found in a number of GM vehicles.
Regals powered by a 2.0-liter turbocharged and direct-injected inline four-cylinder will start rolling off the boat in August pumping out 220 horsepower and a very healthy 258 lb-ft that peaks at just 2,000 rpm. The first batch of turbo Regals will all have automatic transmissions, but buyers will also have the option to get a six-speed manual gearbox later this fall, a first for the Regal.
The Regal's naturally aspirated 2.4-liter (left) and turbocharged 2.0-liter (right) four-cylinder engines
For our driving evaluation we had a mix of normally aspirated and turbo Regals, all with automatic transmissions. Despite the fact that we would be driving on the autobahn and Nürburgring, the suspension, brakes and all-season tires on each Regal we drove were the same parts that will be on cars going to American customers. Since the turbo models weren't final production units yet, their molded plastic engine covers were still wearing UK market Vauxhall badges.
Before we hit the autobahn, we spent a couple of hours exercising the Regal at Opel's Dudehofen proving ground. The proving ground staff were polite enough to spray the vehicle dynamics pad with water and we got to run the Regal through some slalom, moose test and brake-and-steer maneuvers.
The slalom was an excellent test of the Regal's hydraulically assisted steering, as well as the basic transient response of the suspension. Unlike the legendary turbo-V6 Regals of the 1980s, these cars can actually change direction with surprising agility and brake hard repeatedly without immediately fading, a trait that would prove handy the next day.
The moose test became famous back in the late-1990s when a Swedish magazine rolled an early Mercedes-Benz A-Class in a simulated obstacle avoidance maneuver. The test involves entering a gate of cones, making a quick change to the adjacent lane as if to avoid an obstacle in the car's path, and then returning to the original lane. We ran the test at progressively higher speeds up to about 45 mph and the Regal was rock solid stable. The stability control was seamless when it did activate, simply keeping the car on the requested course without ever feeling like it was jerking the car around. (A tip of the hat to the author's former colleagues at TRW for their work on the stability control).
The day after our test track session we picked up our fleet of Regals at the Russellsheim factory outside of Frankfurt for an on-road drive. In addition to the automatic transmission cars that we drove at Dudenhofen, Buick brought along a pair of Insignias with the 2.0-liter turbo and six-speed manuals for us to sample.
We set out northwest from the factory on the autobahn toward Cologne and the Eiffel mountains, home of the world's longest and most dangerous racetrack, the Nürburgring. Starting in the early-1980s when brands like BMW were gaining in popularity in the U.S., GM tried to foist off so-called "Euro-sedans" on its customers with nothing more than blacked-out trim, stiffer springs and alloy wheels with Goodyear Eagle tires. Needless to say, none of these cars ever achieved the level of dynamic sophistication that made the real European sedans so special.
