 Post subject: Zenvo ST1
PostPosted: Thu Feb 11, 2010 10:47 am
Zenvo was started by three people who decided to attempt what the likes of Bugatti, Pagani and Koenigsegg had done before them.
The objective, according to company boss Jesper Jensen, was not to build a road rocket that could outdo the Veyron in terms of raw pace (although the claimed figures – 0-62mph in 3.0sec and 233mph max - aren’t too shabby). Instead, the idea was to come up with car that could easily be driven every day, yet which could also double as a track weapon.
The ST1 was initially designed as a rolling chassis, built around a steel backbone with double-wishbone suspension and three-way Öhlins adjustable dampers.
The massive supercharged and turbocharged V8 was positioned longitudinally directly behind the passenger cell, and the armoury of radiators and other ancillaries were then scattered around the car.
Once all the hardware was in place and functioning to their satisfaction, the Zenvo crew called on Danish designer Christian Brandt to pen the contours of the carbonfibre bodyshell.
The car you see here is the prototype, which has clocked up more than 45,000 miles - and isn't looking at all shabby for it.
The V8 motor is roused into action by twisting an ignition knob on the centre console to the right, depressing the clutch and then pressing the start button atop the chunky piston-shaped gearlever while simultaneously giving the gas pedal a generous prod or two. The 7.0-litre motor erupts into life with a raucous bark, but it immediately settles into a civilised idle.
The clutch doesn’t call for Schwarzenegger-esque quadriceps, but slotting the six-speed Ricardo gearbox into first gear (or any other ratio) requires a firm hand. Zenvo technical guru Troels Vollersten explains the gearshift linkages are a bit worn on the prototype car, and that a new set would make for far easier shifting.
The ST1 has three engine modes – normal, sport and race – liberating 650bhp, 850bhp and 1104bhp respectively, and selection of any of these is a mere twist-knob away. Traction control is fully operational in the normal mode, and partially so in sport… but you’re on your own in the full-power race mode.
The seat of my pants tells me even the 650bhp setting will be enough to see off most rivals, provided you’re deft enough with your clutch and gearchange work. This is no Honda S2000-style rifle-bolt gearchange requiring mere flicks of the wrist. Instead you need to manhandle the alloy knob from one ratio to the next as shifts are neither light nor quick (but perhaps the new linkages alluded to earlier would help).
The engine’s power delivery is relatively smooth and progressive – there’s no alarming peaks or troughs – but the blown V8 doesn’t particularly enjoying lugging at low speeds in high gear. This, plus the stubbornness of the manual gearbox, suggests the six-speed paddle-shift sequential – made by Xtrac – will be the better choice for most.
In no-holds-barred 1104bhp mode the ST1 is virtually as quick as anything I’ve ever driven – Bugatti Veyron included. However, where the Bugatti cossets you and insulates you from much of the violence taking place in the engine room, the Zenvo assaults you with an aural and physical battering.
Unleashing the full quota of power is partially achieved by opening up flaps in the exhaust, which means noise levels instantly escalate to conversation-killing levels, and full-throttle gearshifts are accompanied by a slight twitch from the chassis as 1055lb ft of twisting force does its best to unstick the steamroller rear tyres from the bitumen.
The brakes are massive Brembos (380mm at the front and 355mm at the rear), but given that I’m being intensely scrutinised by Vollersten, who’s riding shotgun, I resist the urge to stomp all over them.
Ride quality is somewhere between firm and rock-hard, but the production car will have a choice of three settings – comfort, normal and sport. Vollersten says shock-absorber specialist Öhlins could provide up to 30 settings for their dampers, but this would be just too much choice for most owners.
Should I buy one?
See more Zenvo ST1 pictures
The key question: is the Zenvo special enough to warrant its exorbitant price tag? To be honest, I can’t quite see £750,000 worth of value in the car, but perhaps the lure of being one of only 15 people to own an ST1 will be the clincher for some. Those that miss the boat will have to hold out for the ST2.
Gautam Sharma
Pictures by Bahr Al-Alum Karim First drive data
How much?
Price as tested TBA
Price as tested £750,000
How fast?
0-62 mph 3 sec
Max speed 233 mph
How big?
Weight 1376 kg
How thirsty?
Combined no data
CO2 emissions no data
Engine
Layout V8
Max power no data at 6900 rpm
Max torque no data at 4500 rpm
PostPosted: Thu Feb 11, 2010 1:56 pm
I really like it. Way better looking than a Veyron, that's for sure.
My Blog
PostPosted: Thu Feb 11, 2010 5:34 pm
Geez, that turbo is the size of a honda engine.
PostPosted: Thu Feb 11, 2010 9:32 pm
that thing looks killer!
Jason Mauldin wrote:
Geez, that turbo is the size of a honda FIT.
fixed
#77 nasa spec 3
e36 M3
