 Post subject: 1993 BMW 325i sedan 5-speed track / autocross / street $3250
PostPosted: Sat Jan 17, 2015 3:42 pm
1993 BMW 325i sedan 5-speed track / autocross / street car - $3250
1993 325i sedan, 5-speed manual, black on black with 165k miles. This is a car that I have fixed up and upgraded for use as a street car and track car -- Mechanically it is in great condition -- LOTS of recent work, reliable, and fun on the street or around an autocross course, but cosmetically it is not perfect and has some flaws which I have not addressed (could use a paint job). This would be a great car for someone looking for a cheap, reliable, well set-up car for track or autocross, or put a back seat back in (if that matters to you) and have fun on the street. Has Ground Control coilovers, camber plates, Koni shocks, and an M3 limited slip differential, plus more (see below).
The chassis is a straight southern car with no accidents and no obvious paint work. Original paint and interior aren’t great but it looks good from 20 feet -- see the list of all the known minor issues with the car below. Street legal and with valid inspection. All the car major functions work fine with no error lights on the dash -- AC is good and recently charged, lights all work, etc. This car has been used at two High Performance Driver’s Education events by my wife, and it worked great.
Comes some spares -- brakes, pads, original parts, etc. Currently a pair of nice stock E36 M3 sedan seats are installed but there are eye bolts for a driver’s side harness. I had a (borrowed) rollbar in it but had to return it. Clear title in my name, ready to sell.
Located in Cary, NC. Call or email Mike at whit32@gmail.com or 919-454-5445
Track prep goodies
Koni sport adjustable shocks
Ground Control camber plates
Ground Control tubular front swaybar
E36 M3 limited slip differential
Hawk HT-10 pads (½ worn)
Rogue transmission mounts
Driver’s side harness eye bolts
RTAB limiters
Clutch stop
Other nice stuff
OEM BMW E36 M3 Exhaust
Ronal 17x9 wheels with good all-seasons
Nice front seats from a E36 M3 sedan
BMW 45p keyless entry system
Aftermarket steering wheel and Momo hub/adapter
Sunroof completely removed and replaced with aluminum panel
Disabled steering column lock and clutch switch
Removed CDV
Custom fabricated underpanel
Ebay chip
Recent maintenance
New front brake calipers and hoses
Replaced Guibo / flex disc
Replaced Water pump, t-stat housing
New Radiator
New Tierods
New Front control arms and M3 bushings
Replaced Valve cover gasket
New Spark plugs
New RTABs
Rotella T6 engine oil
Redline trans fluid
The bad
Paint has a lot of flaws, scratches and is thin in spots -- looks nice from 20’ away but you can see the problems up close.
The keys do not fit the door locks, but the keyless entry works fine for locking/unlocking
Steering wheel is missing the horn button (cheap on ebay)
Battery tray is rusted out and needs a patch (I can fix this prior to sale if it’s an issue)
Carpet is stained in spots
Radio sucks
Might have an unbalanced tire, vibrates a bit on the highway (with these tires)
OBC display is missing a few lines
No rear seat - was junky and was removed for a rollbar (not currently installed)
Fuel gauge occasionally sticks on “e”
Dent in the right rear under the tail light, plus a bunch of door dings
The vanos might be starting to rattle, could be due for a rebuild.
Passenger outside door handle sticks sometimes
 Post subject: Re: 1993 BMW 325i sedan 5-speed track / autocross / street $
PostPosted: Tue Jan 27, 2015 6:31 pm
SOLD
PostPosted: Wed Jan 28, 2015 10:55 pm
And the new owner immediately wanted to sign up for the Rallyxcross school. I think I sufficiently encouraged them to try the AX T&T instead.
Charlie G
1998 BMW Z3
1987 BMW 325is
2000 BMW
1996 F250 Turbo Diesel
PostPosted: Thu Jan 29, 2015 2:09 am
Jeanne's a good sport :) I had my instructor hat on the whole time she was looking at the car, encouraging her to buy a stock car to start with, and that the 325 is too low for soft rally-x, etc. I did everything I could to talk her out of it, ha! But in the end she had too much fun driving it and had to buy it :)
PostPosted: Thu Jan 29, 2015 7:47 am
You bought a drug dealers car and now you are apparently selling Motorsports Crack to poor innocent girls.
