 Post subject: FS: 2002 Honda s2000
PostPosted: Fri Oct 17, 2014 11:01 am
2002 Honda S2000
The Awesome:
48k miles
Garage kept good condition clean non-smoker car
Top is in good shape no tears or leaks
Saner/Addco front sway bar
Koni singles with ~12k miles
Henry's muffler shop straight pipe
All body panels have matching vin stickers
Clean CarFax and Autocheck
4-16x7.5 OEM wheels machined to fit front hubs
New battery
Oil analysis look perfect according to blackstone
After market alarm
Recent alignment
Calipers are painted red
All of the fluids have been replaced except the coolant. I replaced the brake guide pins/bushings, clutch master cylinder, engine mounts, rear diff mounts, and accessory belt. I also still have the oem shocks, front sway bar, front wheels, and mufflers
The not so awesome:
The drivers side rear quarter panel has been repainted and there is a bit of over spray near the lower sill. I have never been able to figure out if there was anything damaged.
Has some scratches on the front lip and a couple door dings.
Current yokohama AD08's are worn. Fronts are good but rears will need to be replaced in the near future. Calipers are painted red.
$12500
 Post subject: Re: FS 2002 Honda s2000
PostPosted: Fri Oct 17, 2014 12:38 pm
MarcusMcRae wrote:
2002 Honda S2000
The Awesome:
47k miles
New battery
After market alarm
The not so awesome:
All of the fluids have been replaced except the coolant. I replaced the brake guide pins/bushings, clutch master cylinder, rear diff mounts, and accessory belt. I also still have the oem shocks, front wheels, and mufflers.
$13500 obo
And it has never been launched hard :twisted:
2005 Mazda 6 Wagon
PostPosted: Fri Oct 17, 2014 12:59 pm
PostPosted: Fri Oct 17, 2014 2:20 pm
Andrew Jonell wrote:
You guys make it sound like that's a bad thing. :D
 Post subject: Re: FS: 2002 Honda s2000
PostPosted: Sat Oct 18, 2014 10:32 am
Drool
2005 GMC Sierra
1991 318is Garage Ornament
PostPosted: Thu Jan 08, 2015 6:17 pm
Bump for price drop!
PostPosted: Thu Jan 08, 2015 9:55 pm
Is your camera broken? - AB
PostPosted: Tue Feb 03, 2015 1:46 pm
Added some pics.
PostPosted: Wed Feb 04, 2015 1:02 am
Paging Noah Fleming to the white courtesy phone....
