1995 Avus Blue M3 Track Car
136,4xx Miles
Exterior:
Avus Blue
Minor crash damage to front right has been professionally repaired and painted including new headlight and front bumper
Paint is in good shape for an almost 20 year old car but is not without some nicks and bumps from 4+ years of use on the race track. Clear is peeling a little on the right mirror only. Southern car its whole life so there is no rust on it.
Clean title.
Interior:
Driver Side: Ractetech 4000w seat
2006 Date/Expired
Blue Schroth Hybrid Harnesses w/2” lap belts and 3” shoulders good through 2015
Racetech sidemounts on VAC long floor mounts
Passenger Side: Sparco Sprint V Seat 2010 Date
Black Schroth Clubman Harnesses Valid until 2015
VAC Sidemounts on VAC long floor mounts
White Powder coated Kirk Roll Bar
Still has carpet and door panels in the front, rear has been stripped to the sound deadening.
No radio, VDO oil pressure, oil temperature, and water temperature gauges installed where radio was
Suspension:
Koni Sport adjustable shocks and struts
Stock Springs (new H&R sport springs available separately, never installed)
Turner adjustable rear lower control arms
96+ strut mounts up front reversed for more negative camber with bimmerworld camber shims installed
Ground control RSM
New outer ball joints in the rear
Drivetrain:
UUC Evo short shifter
Bimmerworld group N replica engine mounts
Rogue engineering transmission mounts
Brakes:
UUC stainless steel lines front and rear
Recent blank rotors installed front and rear
Wheels:
Stock DS1 wheels with 235/40/17 Dunlop Star Specs with decent amount of tread remaining
Mantenance:
Extensive folder of receipts/records of maintenance available
Highlights include new clutch around 125,000 miles
New control arms, tie-rods, and solid control arm bushings around 127,000
New radiator, expansion tank, hoses, belts, pulleys and electric fain installed 136,000
$9,995Car is located in Winston-Salem, NC
