 Post subject: FS: Honda EF Civic parts
PostPosted: Wed Feb 27, 2013 1:49 pm
Thermal CL exhaust system for a 88-91 honda civic si for sale. Still in orig. boxes. - Brand new - $400
1988-1991 Honda Civic Hatch - All
Thermal CL exhaust systems are designed for bolt-in applications and have a deep, throaty sound. CL systems are tuned towards the upper mid-range and top end and are recommended for the more aggressively built vehicle.
Full Stainless Steel
2.25 dia tubing
High Polished for Show Quality Looks
Hand Welded and Tested for Peak Performance
Random Technology Direct Fit High Flow Catalytic Converter - Brand new - $150
Random Technology makes some of the highest flowing direct-fit catalytic converters available. Independent testing by engine builders, racers, and automotive magazines has repeatedly proven the superiority of the Random Technology SuperStainless design.
Key Features:
Direct-fit installation.
Better performance than original equipment converters, at considerably lower costs.
Greatly improved midrange and high-end power/torque.
High quality, stainless steel construction.
Gives a deeper, throatier exhaust tone.
Comes with an attached downpipe section, if applicable.
Meets Federal EPA requirements.
Metallic Converters: Applications labeled as "Metallic" feature a high quality metallic catalyst core which provides superior flow and durability.
fits:
1988-1989 > Acura > Integra > 1.6L
1994-1995 > Honda > Accord > 2.2L
1988-1993 > Honda > Civic > 1.5 & 1.6L
1988-1991 > Honda > CR-X > 1.5 & 1.6L
Progress 24mm solid rear sway bar - used - $125
Includes everything except mounting brackets needed for subframe.
Ground Control front springs(2) 430lb x 2.5"dia 7" length - used - $60
GS - 17 Honda Civic Si
STS - 91 Honda Civic Si
S04 - 00 Subaru Impreza 2.5 RS
http://www.kestrelracing.com
