I bought these with the intention of upgrading my E30 brakes, never got around to it... now I don't have the bimmer any longer =(
These are pics I got from the original owner before they came off his Audi... they actually look better in person... they've not even been out of the box after I received them.
For use on an E30, they'll need a mounting bracket and Scirroco rotors. (I found a source for the mounting brackets through
http://massivebrakes.com/ but never purchased.)
Carbotech XP10 pads included... they appear to have been used simply to ensure the calipers worked... full pad depth, no scorching or anything like that, but you can tell by the backing plates they have seen some force.
$300 shipped or deliveredWilwood billet dynalite 4 piston calipers
model 120-5094 for 1" thick rotors.
Shims can be added or removed to fit .38" .50" .81" 1.00" and 1.25"
comes with four shims in each caliper as shown in the pics.Will fit rotors up to 13.06" in diameter
Only 2.66lbs!
Takes Wilwood type 7112 pad
1.75" pistons
(brackets not included)
Also includes cotter pins and some type of 90 degree threaded fitting which I have no idea what it would be used for.
New condition, less than 200 miles on them!
Newest picture:
