Post new topic Reply to topic  [ 251 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17
 Post subject: Re: SOLD 2004 Honda S2000, Grand Prix White on Tan, 53k mile
PostPosted: Wed Nov 14, 2012 11:41 am
Chuck Branscomb wrote:
Mike,
I know you like older things a bit, but seriously that looks like a screen capture from DOS 2.01 days... :) Or is this some personal program you wrote in TurboPascal years ago and still use in XP-emulation mode?
Hey if it makes it more impressive, then sure :) No, it's just excel.
PostPosted: Wed Nov 14, 2012 12:41 pm
$3,500 seems very cheap for 2001 330i. Good going. I love the spreadsheet!
PostPosted: Wed Nov 14, 2012 8:39 pm
In retrospect I knid of wish I had waited for a nicer one. This is one example of a E46 where if it could go wrong, it is going wrong. Has literally every single textbook problem. All of them repairable, and I should have a near-perfect car for less invested than a typical used E46 out there.
PostPosted: Thu Nov 15, 2012 9:53 am
Mike, what control arm bushings did you get from Amazon? At $21, I'm assuming it's just rubber that needs to be pressed into the housing or is it the housing and rubber bits?
Mine are in decent shape for the abuse they've seen but I might just do them anyway, or put some poly there.
PostPosted: Thu Nov 15, 2012 10:08 am
so, for the Excel idiot (creating one like this anyways) would you be willing to make available the template you use to the masses? 8)
While I am amazed and not that OCD, I like this and would like to use this for my fleet.
PostPosted: Thu Nov 15, 2012 10:39 am
Press in
http://www.amazon.com/gp/product/B003UL ... 00_s01_i01
PostPosted: Thu Nov 15, 2012 10:52 am
I think these bushings are different for ZHP control arms fwiw.
PostPosted: Thu Nov 15, 2012 11:09 am
They are still 66mm bushings so is the inner hole different sized or does the ZHP just have a stiffer version of the same bushing?
PostPosted: Thu Nov 15, 2012 11:47 am
I've not looked at it in years, but I think the ZHP bushings are stiffer -- part of the M-sport pkg control arm setup. Maybe check out realoem to be verify.
PostPosted: Thu Nov 15, 2012 11:58 am
Fortunately I had the opposite problem with our e39. It was high enough miles that the previous owner did all of the textbook problems. In the end since you can do the work all you will lose is time and end up with a solid car.
PostPosted: Thu Nov 15, 2012 6:27 pm
Ah yes, the Msport and M3 bushings are solid rubber whereas the regular 330 FCABs are oil filled for damping purposes.
