 Post subject: Forum error code
PostPosted: Sat Jan 24, 2015 8:51 am
FYI.
I got this on the main page.
[phpBB Debug] PHP Notice: in file /index.php on line 86: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone.
[phpBB Debug] PHP Notice: in file /index.php on line 86: getdate(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone.
I did a refresh and reload of the page in a different tab. Still there. Browser is FF
 Post subject: Re: Forum error code
PostPosted: Sat Jan 24, 2015 9:32 am
I am getting the same error with Chrome.
