Mark Vitacco wrote:
Can you get more photos and the tube size spec's?
Then we can make the call for sure. I would be happy to add photos example for the Tech Guide.
The information I'm finding on the Cusco (the blue one) is sort of all over the place.
This place says the bars are 40mm - no wall thickness specified:
http://www.vividracing.com/catalog/cusc ... -5104.html. Of course, it also says that the bar "won't work on vehicles with a sunroof or moonroof," so the whole page seems suspect.
This thread, on s2ki.com, is about five years old now - but it does raise some issues with the Cusco bar:
http://www.s2ki.com/forums/index.php?sh ... try4145008 I can't help noticing that the places that sell the Cusco bar often make a point of mentioning that it's chromoly, and very light weight. Which leads me to believe the wall thickness on the tubing might not be up to standard. So far, I haven't found the actual data.
So...here's a picture of a version of the Cusco from a different angle:
And, it demonstrates a problem - at least, a problem for my particular case. Notice the way the main hoop goes down the bulkhead, to the floor. That's fine and all - but, if you want to keep the factory seats, you're forced to give up about 3 inches of seat adjustability. This with a car that isn't famous for having a lot of room in it.
So now, you're faced with either cutting up the factory seats, or, more likely, fitting a pair of racing seats. Which, I think, is necessary anyway, to get the harness belts to work properly. This takes the car out of A Stock, which isn't something I want to do.
The right solution, for me, is probably to start hunting for a salvage title S2000. Something I wouldn't care as much about cutting up. This one's way too nice for all this.
I'm looking for better pictures of the Mugen bar. It looks to me like the main hoop legs go fairly far forward into the floor of the car - if that's so, the same seating problems reveal themselves.
