 Post subject: In car communicators
PostPosted: Thu Sep 04, 2008 1:13 pm
Looking for some advice on purchasing a communicator for instructing ...
This Chatterbox seems to be almost the de facto standard:
http://www.chatterboxusa.com/cb_50.html
Chatterbox now makes a bluetooth enabled version:
http://www.chatterboxusa.com/xbi.html
Yea, it costs a bit more, especially since you need to buy two. There are certainly advantages to not having wires although I guess some folks already have headsets mounted in their helmets for the "standard" plug.
Any experiences here with the bluetooth device? Thoughts?
Thanks,
Frank
PostPosted: Thu Sep 04, 2008 1:42 pm
FRank, the HJC-50 is a good reliable unit, just don't use the bracket that comes with it. That bracket put mine in a bind and cracked the circuit board...thus I had to buy another this past weekend from CDOC at VIR. I plan to attach the com unit to my helmet with just velcro this time.
Also I'd go ahead and spring for the stereo headset which is made to stay in your helmet. That way you can just hand the remote headset to your student and yours is always in place.
PostPosted: Thu Sep 04, 2008 3:05 pm
I just want someone to make an adapter for the Chatterbox wired unit so that I can plug my already wired helmet into it. Something that adds a PTT button and let's me use the standard motorola radio connection.
 Post subject: Re: In car communicators
PostPosted: Thu Sep 04, 2008 5:10 pm
Thanks,
Frank
You can always use the "Blue in the Face" model which means you yell at the top of your lungs at the student all your instructions ;-)
PostPosted: Thu Sep 04, 2008 8:51 pm
Or, be like my first PCA instuctor who used hand motions! This was the same guy that said "if I puke we have to come in"!
PostPosted: Thu Sep 04, 2008 10:05 pm
Sometimes hand motions are a necessity.. ask anyone who's ridden with/near Brian Smith (in the burgandy fox-body Mustang that ran with us a few times.)
Stacy King
Midlife Crisis Participant
PostPosted: Fri Sep 05, 2008 10:46 am
Hey,
Hand motions? Was that in the instructor classroom lecture? Did I forget already?
:D
Frank
PostPosted: Sun Nov 16, 2008 4:12 pm
Are the cables on the student headsets long enough or are extension cables needed?
PostPosted: Mon Nov 17, 2008 8:15 am
You'll need an extension cable for your student. Pretty sure the standard main unit comes with one.
Frank
 Post subject: How long does it take to charge?
PostPosted: Thu Dec 25, 2008 1:29 pm
Santa brought one, but the elves neglected to mention how long these babies need to charge in the documentation.
 Post subject: Re: How long does it take to charge?
PostPosted: Thu Dec 25, 2008 8:44 pm
Overnight is fine Matt. If you don't forget to turn it off after each use, a single charge last a remarkably long time.
PostPosted: Mon May 25, 2009 3:45 pm
Groovy, baby!
After three years of extensive use my JC-50's battery finally ran out of charge cycles. Replacement Ni Cads batteries are available for $12.
I tie wrap the cable to the mike boom near the ear piece.
It is possible to pull the cable out of the earpiece and this will help
prevent that. The only negative I found is that its possible to break
the mounting bracket.
Mark Vitacco
THSCC TT Chairman
mvitacco@bellsouth.net
PostPosted: Thu Jun 18, 2009 4:29 pm
Had two Chatters...
One head set had horrid terminal feedback at ~20% volume.
Box had faulty DIN jack... plug would not stay in, and you couldn't even hold it in place and get consistent connectivity.
Replacement headset ok.
Replacement box had same problem as the first...
The supplier, OG Racing, gave excellent service trying to resolve the issue, even making sure I received the replacement the next day in time for HPDE the following day.
Afterwards in an attempt to find a working replacement they checked all they had in stock and all had same issue. One of their employees who used one said, 'Oh yeah, they're like that.'
In addition to the jack problems I found the 'thick' ear speaker to be very uncomfortable.
Went with Nady... and yes it has the well known issues re delicate wiring and some RF interference problems. However, with some simple mods I've resolved most of the weaknesses in the wiring. Only had one set whose wiring got broken and that took the student some doing to accomplish.
Believe it or not, and I didn't at first, the manual's bold red letter admonition to Keep the Plugs Clean does make a difference. They sure as heck don't look dirty and I've never had problems with similar jacks in the past, even a small amount of oil, etc. from ones fingers or some such can actually cause some static issues. When the problem begins, cleaning with denatured alcohol seems to work. I use a 3M Scouring pad for this.
I also find the 'thinner' ear speaker considerably more comfortable. And the price helps putting up with the cons. I also prefer regular batteries to rechargeables, and they last quite awhile when turned off while not in use. I think the last time I changed them was early last year with ~15 events since then. Cheap ones at that.
FWIW my set has worked quite well over the past year and up through my last event this past weekend. Problems with hearing volume can usually be traced to not having the small speaker openings directly over the ear canal. And of course this OF's ol age hearing loss.
If you've actually read this far, save all the 'I ain't had any problems and love my Chatter Box' refrains as I'm quite aware that my situation is not typical of the CB's performance and reliability. I just got fed up and after working with the Nady to get it acceptable, I'll stick with it for now, thank you very much. I would add that Chin MS uses Nadys for their rental units and if they were consistently real crappy I'd bet that'd get changed in a hurry.
I might also add that this kind of thing with crap not working for me is typical. Can you say Joe Btfsplk.
Steve 'who got talked into the CB he couldn't afford and paid the price...' Coleman
See nothing... Know everything.
'ol corps rac'r...
 Post subject: Chatterbox to 2-way radio adapter
PostPosted: Tue Dec 01, 2009 5:24 pm
For those instructors that use a Chatterbox while instructing who also have a 2-way radio system, I've got an adapter that connects the two.
So, you can hook up your 2-way radio ear buds/ built in helmet mic directly to the Chatterbox. It works great and is so much more convenient that sliding the crappy Chatterbox mic/ear boom under your helmet. Plus, the sound quality is much clearer.
If interested, please email me at dbbmwm3(at)yahoo(dot)com
-Denis
 Post subject: Re: Chatterbox to 2-way radio adapter
PostPosted: Thu Dec 03, 2009 6:36 pm
-Denis
Wish I'd thought of that earlier. Been trying to figure out a way to use 'ear buds' v head set speaker.
Don't know for sure if it'll work with the Nady, but it does have 2-way and cell phone jacks IIRC. I think you're speaking of a diff deal; not sure. If you're specking of a typical cell phone hands free set up, I'd thought of that but with an open face helmet couldn't figure out a good way to use the in-line mic.
I'm going to check this ear bud deal out, with the ear buds plugged into one jack and still use the head set for the mic.
If I can't make something work I'll probably get up with you for more info.
One question... not sure where the 'adapter' you mention fits in, unless it's due to jack size. IIRC the jacks for cell phones are typ. the smaller dia. So, more info would be appreciated.
TIA,
'ol corps rac'r...
