Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Feb 14, 2008 11:09 am
Matt Nicholson wrote:
Q: so why is it any harder on brakes than VIR T1 or T4 or T14?
A: Cooling time.
After turn 1, you have a tap for Nascar. You're hitting them decently for Left Hook, but how fast are you going there (remember the formula for kinetic energy)? I'm not even at the top of 3rd gear yet at that point. After that, when do you hit the brakes again? A mile later for Southbend? And that's knocking ~15mph off. Some are less. The braking for Oaktree is uphill, as is the braking for Rollercoaster. So on a 3.2mile track, I can find 3 good hard braking points, 2 of which are uphill. How many are there at a 2.2mile CMP? 4? More?
VIR=not all that hard on brakes. Not even close to CMP.
ok... so now with the changes, shouldn't you
1) Not have to slow as hard for the Carousel, T8, T11, T14 (new pavement in all turns, re-config for T12, T13, T14) since you're able to carry more speed through them
2) Let the brakes cool a little more between T8 and T11, then again from T12 to T14
I'm not suggesting it will be as forgiving as VIR, it's a full 1-mile shorter. But by the same token, you can't really complain about it being worse right? You have to deal with it the best way possible... ducting, driving style, pad compound. Obviously, you can't (shouldn't even) be able to run the same pad compound at CMP that you would at VIR.
Stacy King
Midlife Crisis Participant
PostPosted: Thu Feb 14, 2008 11:15 am
An unpopular opinion perhaps, but one thing I'l miss about CMP as a learning experience for people is that it teaches you how to save the equipment. With CMP 1.0, if you go out and tear arse for 30 minutes, you *will* notice a difference in braking with your car. Pretty much any car. These were lessons that served me well in endurance racing.
The new layout, obviously, is TBD.
PostPosted: Thu Feb 14, 2008 11:21 am
I was extremely displeased with the pictures of the pads I saw after 6 20-minute sessions.
i don't recall anyone having any braking issues in the 3hr enduro on friday...also pretty sure the car i co-drove on friday went on to finish the rest of the weekend (2 qualis, 2 sprints, and some practice time) on the same pads/rotors that we ran in the enduro...these were hawk ht-10's
the new layout seemed to be easier on brakes...not easy on brakes but better than before...
with the new pavement in many turns, corner speeds are higher and the new configuration elminates one brake zone and gives a lot more time for brakes to cool before braking for t14
David White
95 M3 - #275 BMWCCA JP, NASA GTS-3
02 M3 - street/track
05 Suburban 8.1L
PostPosted: Thu Feb 14, 2008 11:56 am
Physics: You fail...
Kinetic energy increases with the SQUARE of velocity (KE=1/2*M*V^2)
You have much much more kinetic energy at 100mph than 90mph. So even if you scrub off the same 50 mph, you are scrubbing off a whole lot more kinetic energy....
A very quick guestimation on excel says 15% more KE for a 2800lb car....
Matt,
While I realize you are an engineer and I am not, I am having a hard time with the logic of the KE of the formula you posted. Yes, KE goes up as the square of V, but the F of the de-acceleration is the same as long as the change in velocity is the same. So a 50 MPH change of a 2800 lb car is the same (not given assistance of Wind Resistance) as long as the time is the same. The KE comes into effect if the velocity is not the same. I remember the change in the kinetic energy of an object is equal to the net work done on the object. So KE comes into play when KE is converted to force or work.
Ie:
W(net)=1/2*MV^2(second) – ½*MV^2(initial)
But actual force used to cause the change in velocity should be the same otherwise the standard F=MA formula doesn’t apply. So the actual force applied to the pads should have not changed.
Maybe I am remembering all this wrong.
PostPosted: Thu Feb 14, 2008 12:01 pm
Marty,
You hit the nail on the head without realizing it -- the acceleration (or deceleration in this instance) is missing a time component. The rate of the change is the difference.
PostPosted: Thu Feb 14, 2008 1:13 pm
Or to think of it another way --
Energy = Work = Force * Distance
During threshold braking from 100MPH to 50MPH you'll be braking with the same force, but a longer distance, than you would from 90MPH to 40MPH. Thus more energy.
Same force, same delta V, but longer distance, and thus more work or energy. Due to the higher initial V.
PostPosted: Thu Feb 14, 2008 1:15 pm
Per Stacy's scenario:
Old config: 90-40 mph
new config: 100-50mph
Thing is, you're NOT slowing completely from 90mph, you have to subtract the amount out that you're not slowing, which is 40mph. So the equation for the old way looks like this:
Work(old)=.5M(90)^2-.5M(40)^2
The new way is the same thing, with higher velocities for both Vs.
Work(new)=.5M(100)^2-.5M(50)^2
Now, .5M is a constant (same car), so we can just drop that out of the equation, since we're looking for the change.
W(new)/W(old)=(100^2-50^2)/(90^2-50^2)
That says Delta W is 15%. Same change in velocity, but that whole squared thing really kicks your butt....
Very fair. I only have 1 data point so far. But it was a bad one...
PostPosted: Thu Feb 14, 2008 1:49 pm
I'm having trouble here. Are Mike, Wes and I in agreement? It kinda sounds that way....
PostPosted: Thu Feb 14, 2008 1:57 pm
Yeah, but, it's 15.34% more energy :)
PostPosted: Thu Feb 14, 2008 2:02 pm
I think that we're saying the same thing using different words.
PostPosted: Thu Feb 14, 2008 3:08 pm
Hmm. Odd. I get 15.38%.
:whoknows:
PostPosted: Thu Feb 14, 2008 3:12 pm
:whoknows:
One of you has a calculator that is out of calibration.
-Jeff
R1 Powered Locost 7
ITB '90 Honda Civic under construction
2004 F250 Super Duty
http://www.project-seven.goof.com/
PostPosted: Thu Feb 14, 2008 3:40 pm
I don't have a calculator. I have a phone that occasionally adds shit up...
PostPosted: Thu Feb 14, 2008 3:45 pm
Well there's your problem Matt. Your calculator isn't SFI certified. I'm guessing Mike's is.
PostPosted: Thu Feb 14, 2008 8:59 pm
Ryan mentioned my data logging info. If anyone is interested I can send the file along. You can download the viewing software (traqview) from Tarqmate's web page. Its a bit difficult to find so I can also include the address. Send me a note directly: ron.e.spencer@gmail.com
Its quite fun to see exactly what speeds are being carried into braking zones and through corners. DL keeps one from telling "big tales".
Ron
