 Post subject: In-car from Saturday TT at the Rock
PostPosted: Mon Oct 08, 2007 6:07 pm
Hey gang,
Thought I would share my in-car from the TT on Saturday. Turn 5 was slick as snot all weekend, but I delt with it as best I could. Turn 7 was trying to kick my ass every lap going over the transition as well. Guess that is part of what makes Rockingham so fun.
http://www.project-seven.goof.com/videos/LCRock1007.wmv
-Jeff
R1 Powered Locost 7
ITB '90 Honda Civic under construction
2004 F250 Super Duty
PostPosted: Mon Oct 08, 2007 6:43 pm
Mazda Crash Test Dummy
Nice drivin' Jeff.
Kevin Butler
2003 C5 Z06 Corvette
PostPosted: Mon Oct 08, 2007 8:45 pm
Evil.
 Post subject: Re: In-car from Saturday TT at the Rock
PostPosted: Tue Oct 09, 2007 8:44 am
Jeff Underwood wrote:
Hey gang,
Downloading now... can't wait to see it Jeff. I'm glad I'm not the only one who thought 5 was slick. I sure hope someone got some in-car from behind me... I want to see how my drift practicing went :D Sure felt fun!!
I'll have some in-car of my own soon... just need to process and upload
Stacy King
Midlife Crisis Participant
PostPosted: Tue Oct 09, 2007 10:26 am
That's really cool! Thanks for sharing. I want a shifter like that.
Rubbin' is Racin'
PostPosted: Tue Oct 09, 2007 3:05 pm
BTW,
you should have heard some of the words out of Stacy's mouth when he realized the camera wasn't on during his best session.
PostPosted: Tue Oct 09, 2007 4:07 pm
Really nice video. Enjoyed watching it!
PostPosted: Wed Oct 10, 2007 1:44 am
Here's my in-car from Sunday's time trial, group 2.
Looks a bit less dramatic on video, but note how many times I'm counter-steering through and out of T5 and T7 (sometimes T3).
http://video.google.com/videoplay?docid ... 3693&hl=en
-Stacy
Edit: Using MyLaps.com... Lap #9 was my fastest TT lap at 1:14.09x
My fastest of the weekend appears to have been during the last DE session on Sunday where I recorded a 1:13.96x
I'm tickled pink to be only @2.5 seconds off Matt Nicholson's times
Stacy King
PostPosted: Wed Oct 10, 2007 8:32 am
And now for something completely different (or at least slower :wink: ) -
http://video.google.com/videoplay?docid=-3832645271123389016&hl=en
Entertaining only for the Porsche-harassment, and the lesson learned about the curbs at around 6:30 in. Maybe send that to Scott for a "greatest hits" video?
PostPosted: Thu Oct 11, 2007 5:09 pm
Jeff to answer your question about entry into 7 go back and look at your shift points after you pass the red BMW (around 10:30 into the video). You entered turn 7 from about mid track. I'm betting the shift points aren't very different then when you enter turn 7 from further track right.
If I'm correct then you don't loose anything by entering from left of center track which means that if you carry enough speed through 6 so that the car needs to drift center track on exit you don't loose and speed down the front straight.
That said....if for ANY corner your wheels actually were pointed in the direction of the corner for the whole turn things may have been faster! What were you running, roller skates on the back??
Great times in the TT.
R
PostPosted: Thu Oct 11, 2007 5:22 pm
Stacy nice video. A couple comments. It appears you kind of hedge in a bit for turn 5 (second half of fish hook). Next time try staying full track left before turning in for 5. That should help your exit.
Also, for turn 7 its hard to hear the engine over the wind noise but when the car starts to slide exiting 7 try modulating the throttle some (small quick lifts) to keep it from sliding so much. And if the banking catches you and stops the slide don't go any higher onto the banking until WELL onto the front straight. I don't go up on the real front straight until just at or maybe just before the start finish line. With momentum cars like yours and mine the less climbing you do and the straighter you make your exit out of 7 the faster you will be!
I'm not sure these tips will be enough for you to catch Matt (his car is faster) but they should help close the gap a little!
Ron
PostPosted: Fri Oct 12, 2007 9:19 am
R
Actually, caster wheels is more like it...and tell that to Jim Clark and all those guys who used to drive those old F1 cars on bias-ply tires... :D
Back to T7 - Getting into 7 from center track did not hurt me *that* much, but it did make for an awkward transition and you can see the car get upset by it. My physics book tells me that if I have to travel on a tighter arc, given the same amount of grip, then I am going to have to go slower to do it. Now weather or not I am good enough to capitalize on that while driving is a whole 'nuther story. I figure that if I know this, then I should give myself every opportunity to capitalize from it weather I can get there with driving or not. For me the track out of 7 ends about 6 inches before the apron ends. I just can not bring myself to slam a car up onto the banking at that speed.
You know me Ron, I tend to try and drive the tidy line that technically makes the most sense. Of course, after watching the pros on TV, it is easy to see that there is more than one way to skin a cat.
-Jeff
R1 Powered Locost 7
PostPosted: Fri Oct 12, 2007 10:08 am
I will try that next time...
I'm not so sure the TT video was a good example of my T7 technique (I was very inconsistent there all weekend anyway.) There were more than a couple laps where I pushed it through 6, which threw me off for 7. Like Jeff said, the tighter arc is where the rear end wanted to come around on me, even in 3rd gear there.
As far as the apron/oval transition there... I've found a very nice, smooth spot that doesn't upset the car, and still keeps the line tight enough that I don't think it's detrimental. Only time I immediately get up on the banking is when I'm letting someone by or I've really blown T7.
The inside line through T7 can only put you on the banking quicker unless slowing way down in the turn. I felt best with a fast T6, braking hard then turning in for T7 center track and allowing the car to drift out gradually to the transition and naturally (i.e. no addt'l steering input) straddle, then move up onto the banking (well past where Danny and Mark O were moving up onto it last year.)
I know Matt and Mike had some very close battles, I can only hope to not embarrass myself... plus, now that Matt has taken a hit off of some Hoosiers, anyone in DSP will have their work cut out for them LOL.
Stacy King
PostPosted: Fri Oct 12, 2007 10:50 am
Jeff the deal with 6 is that if you want to enter turn 7 classically, you would need to be full track right exiting 6. To do that you have to give up a LOT more speed through 6. However if you carry lots more speed through 6 it will indeed mean you have to let the car drift left to maybe center track, maybe further.
However I've found even with the less then classic entrance to 7 I can still carry lots of speed through 7. The key to exiting 7 is to let the car drift as far right as it wants/ needs. The transition from apron to banking will usually keep the car from sliding further. Its not hard on the car but does stop the slide quickly.
If you combine all these things together you can carry speed all the way through both those turns and not suffer a penalty down the long front straight. Whenever I catch a car in 6 I never loose ground to them out onto the NASCAR portion. Or if I do its only because I have to slow my momentum down so I don't hit them!
Jeff its a LOT like turn 4 at Roebling. My goal there is the same as for 6 at The Rock: exit on pavement. I still carry lots of speed through 5 even though I'm entering it from center track or further track left.
In any event something to think about for next time there.
Ron
PostPosted: Fri Oct 12, 2007 11:06 am
Ron, do you get close to the gator on the right out of 6?
