Ok so I got a hold of one of the Hoosier reps. The A will wear faster than the R. But you can use them for track. Apparently Hoosier doesn't distinguish the tires quite the way we all interpret them. They wouldn't go along with 4 weekends which is what I was hoping for. 2, maybe 3 weekends. Possibly 1 weekend if I wear the outer edge too much.
I also posted on CF and didn't get much at first but then someone else started a thread on Hoosier R vs A on track and that got the ball rolling.
Aaron, That is what is going to hurt me. I have -1.5 front and -1.0 rear. They told me to watch out for the edge, especially on the 05. So even rotating front to rear, at Hossiers suggestion, they won't last long because I'll cord the edges.
As David White pointed out (he's reading the same thread as me on CF). Let's correct a myth that Hoosier A will explode on track after a few laps. ALL of the T1 racers who run Hoosier use the A6, not just for qualifying, but for the whole race. 3100lb Z06 - Lance Knupp won the runoffs, fastest lap was lap 16! Mr. Heinrocket, fastest lap on lap 13. Then Pintarac in a 3700lb Viper fastest lap was lap 11. So yes Donnie, you could use some to blister off that fast qualifying lap since they will be fast right out of pit road. Especially if you can come up with -3.0 camber.
David, I ran a combination of GY SC that comes on the Z06 and then Nitto R2 (similar to the Toyo RA1). I like them. And they most certainly last a while. Was just curious about trying the Hoosier. Btw, No you can't run at the NCM event in your car. None of the plastic car boys want you running laps around them.
I've ridden with Jody chasing you around VIR. I have a very good idea how fast you are.
So what started all of this. Well I can get a set of new A3S05 in 305/30-18 for $480 shipped for the set of 4. I figured if I could get 4 weekends (or at least 3) out of these. Then 2 sets would cost me less than 1 set of R2 or RA1.
Scratch another theory I had...
Graham
