 Post subject: Need to borrow G-Force cam lock anti-sub strap
PostPosted: Wed Mar 08, 2006 10:56 pm
Groovy, baby!
I will be co-driving the April event with a friend and decided a second
anti sub strap would make driver changes easier. My Scirocco has
mounts for both 5 and 6 point harnesses.
However G-Force does not sell them individually anymore. Does anyone have a G-Force CAMLOCK anti sub strap we can borrow for a weekend?
Thanks
Mark Vitacco
THSCC TT Chairman
mvitacco@bellsouth.net
PostPosted: Wed Mar 08, 2006 11:03 pm
Mark,
I can't help you with a loaner but... I decided to go from 5-point to 6-point because of my factory seats. I found out that G-Force only sells complete sets. However, Simpson sells individual peices. I order the sub strap to convert to 6-point from them. It was only about $21 per side. That is with the standard bolt in belt retainers. Part # 34014-CAM-BLK. Get it directly from Simpson.
Graham
PostPosted: Thu Mar 09, 2006 9:00 am
I've got a Simpson camlock sub strap you can try. I've got both a single strap (5-point), never used, that I'm holding in my hand right now, and a double (6-point) out of the Neon that's around here somewhere... let me know.
Carl Fisher
Be Cool to the Pizza Dude:
PostPosted: Thu Mar 09, 2006 9:33 am
Mark, I have a spare G-Force. Actually. two. I need to check if the one in the box is a Cam lock, it might be a latch. I will check and let you know.
Marty
PostPosted: Thu Mar 09, 2006 2:06 pm
Mark, I have one you're welcome to. Call (615.483.1541) or PM me and we'll figure out how/where to connect.
Marvin McBride
Spec Miata #62
PostPosted: Thu Mar 09, 2006 3:30 pm
Groovy, baby!
Thanks Marty!
If your's is a cam lock (GFORCE) just bring it with you I have an extra
2" snap-in clip. If not, I get up with Marvin. Looks like I found another
reason to stick with SPARCO!
Cheers
Mark V
Mark Vitacco
THSCC TT Chairman
PostPosted: Thu Mar 09, 2006 3:34 pm
Groovy, baby!
Thanks Karl & Gram but a Simpson belt will not work on a
GFORCE Cam Lock.
Mark Vitacco
THSCC TT Chairman
PostPosted: Thu Mar 09, 2006 5:53 pm
GFORCE Cam Lock.
Hmmm.... I have a G-Force 5-point Camlock. I have the Simpson anti-sub strap installed now. I buckled it all together and it works for me.
What doesn't work about it? Maybe I'm missing something here...
Graham
PostPosted: Thu Mar 09, 2006 9:58 pm
Mark,
Turn's out I have one of each. The problem is the Camlock is in the car and the latch release is in the box. The Latch release is a full set with click connectors if you want to do a quick belt change. It's a brand new set.
