Graham Jagger wrote:
I've installed a harness bar (not a roll bar). It is 4-point mounted to stop the bar from twisting and does help strenghten the B-pillar (halo). I installed 5 point harnesses with stock seats. They help a lot at keeping you still in the seat. Which helps a lot for autox and I would consider a basic safety improvement in that I feel more secure in the seat.
I'm not familiar with your car nor the details of your particular installation so I will quote the party line: the rule is that the harnesses must mounted per the instructions provided with them and in concordance with the SCCA GCR (on their website in PDF) which is kind-of hard to do without a rollbar/cage.
You mention you installed a 5-pt harness with stock seats - did you cut a hole in the seat for the 5th point so that it is in a plane with your body per the installation or is it just bolted somewhere convenient (which isn't correct)? That is easily rectified by switching to a 6-point if you don't want to cut holes in the seat and drill in the sheetmeal, but you probably would need to drill in the sheetmetal elsewhere for a proper installation...
Harness bars are generally not to be used as actual mounting points for harnesses - they are meant to be guide-bars to position them correctly. When you get your car teched for an event, whoever goes over it should look at your installation and determine if it is correct (as well as your in-car instructor who will have final say in the matter as to if harnesses are/aren't going to be used). If you can't get the belts situated at the angles and mounting points specified, it will not be allowed.
Just because the belts are in there and you feel secure doesn't mean that they are going to be better than the stock belts in terms of safety in an incident. Better to have a properly installed/maintained 3-point stock seatbelt than a full set of harnesses that are improperly installed. Our "preferred" harness solution for stock vehicles with no rollbar are a set of DOT approved harnesses (Schroth).
I would advise you to re-read your harness installation manual, the appropriate GCR sections, our tech guide, and feel free to contact any of the track events staff about concerns _ahead of time_ lest you be dissapointed that you can't use your safety equipment when you arrive at the event and can't do anything about it.
