Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: First time on track with THSCC... Advice?
PostPosted: Mon Apr 17, 2017 5:52 pm
I have heard the RE71s do wear pretty quickly on track. They're a much better AutoX tire than a track tire.
I think ZII Star specs and RS3s are probably some of the preferred street tires for track from what i've heard.
2017 Autocross Chief of Tech
2000 E Street Miata
2015 Fiesta ST (Wife's ride)
PostPosted: Tue Apr 18, 2017 7:51 pm
This is excellent Intel, and much appreciated! Given what "usual" wear is like on the RE71Rs, I shudder to think what "greater than usual" must be like. :wink:
Are there different track configurations at CMP, like there are at VIR (Full/North/Grand/etc), and if so, which will we be running? Clearly I need to educate myself on this kink thing, and turn numbers.
Bart
STR 42
PostPosted: Tue Apr 18, 2017 8:40 pm
Technically there are multiple configurations, but they are never used. We run the full course.
PostPosted: Wed Apr 19, 2017 7:36 am
About the kink if they didn’t made any change since the last time I went there don’t take it too much on the inside, there is a slight bump on the inside that become bigger and bigger the more you take it on the inside.
Some years ago I took it too much on the inside and it send the 911 in a nice 360 with a lots of smoke, luckily it stay on the tarmac.
Patrice
2016 VW GTI
2012 Nissan Juke (Kathy car)
PostPosted: Wed Apr 19, 2017 7:54 am
I just pictured you doing a perfect DannySullivan...hopefully you kept the hammer down and never looked back.
PostPosted: Wed Apr 19, 2017 8:05 am
Have you ever ridden with Patrice? I have, and trust me, he's hammer down most of the time!
PostPosted: Wed Apr 19, 2017 9:28 am
Andrew Jonell wrote:
Your RE71Rs though... might experience greater than usual wear.
You can count on that.
The food stand isn't terrible. There's a Subway up the road if that strikes your fancy vs a chicken sandwich with fries.
The food stand is better than used to be (new owners), but be aware they are slooooow. Get there early, otherwise you be waiting for a while.
One more thing, I'd advise against getting fuel from the station right outside the track. Their 93 grade has been suspect in the past. The track has fuel, but it's quite pricey of course. Just take a right when you leave and head into Kershaw to the Shell station instead.
Plus "he was F-ing with the wrong Patel" raises the price of 93 on race weekends.
The inside of T-11 is a great place to pass :mrgreen:
PostPosted: Wed Apr 19, 2017 1:18 pm
I guess from the outside it might have look like Sullivan at Indy. I keep going like before, I was just more careful in the kink to not take too much of the bump.
With the Miata the bump was less an issue. With the Miata it was flat all the way thru the kink, with the 911, I had to brake for the kink, the speed in the kink was basically the same for both cars according to the data acq.
Patrice
2016 VW GTI
PostPosted: Mon Apr 24, 2017 1:39 pm
One other thing to add. Running soft tires like that at CMP is going to be a bit of a gamble. Be careful and manage your understeer carefully. There are many places at CMP where you are going to want to just plow through it, most of these are right hand tuns. It's likely worth bringing a tire gauge and checking your front left tire after Saturday. It may be worthwhile to rotate your tires. I'd suggest making friends with someone who has a trailer so you don't need to bring a bunch of tools.
PostPosted: Sun Apr 30, 2017 5:06 pm
Watch this video of Jimmy Johnson at CMP. It shows you what happens when you don't do the kink correctly. https://www.youtube.com/watch?v=qT7XBqf1kmY
Corvettes get a little light in the back end over the kink especially if you are lifting as you hit it. The rear wheels go airborne and there is just enough lateral loading on the car to cause the rear end to pass the front. I don't know if this is the best way to do it, but I do a brake brush before the kink and feed it a little gas as I'm going over the kink. This keeps the rear end from going airborne on the bump. This works even if you are tight to the inside gator and lets you give it more gas exiting the kink than you could do if you were going wide. Here's a club member loosing it at the kink. https://www.youtube.com/watch?v=pdS0p_Og3hI It looks like my Vette but it isn't.
Mike Miller
AutoX VP 2016/2017
Just a C Stock Miata DD
Mazda Speed 3 Family Car
Corvette Z06 Toy
