Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: HPDE at NCCAR????
PostPosted: Sun Sep 04, 2016 6:41 am
Thscc only has one event I can do per year, I'll look into track daze too
I got a great instructor this weekend, better than the skip barber school
2008 135i
2005 mini S
1999 540i aka valdez
PostPosted: Tue Sep 06, 2016 8:43 am
well that was a ton of fun, got signed off on solo sunday. I did destroy the outside edge on a brand new set of re71rs, they had 1 autocross on them and now I have to flip them and I should be able to get another weekend on them, going to CMP in november with NASA, plan is still to go to HPDE4 and then decide if I wanna pick up a spec-e30 or build a hpde4 car will see how the mini does on the track with that group first, and I have to get the tire wear under control. I ended up at 43psi hot, when I autocross I run at 35 hot, increasing the pressure did help with outside edge wear I cant tell what it did to my laptime as my lines got better and smoother as I learned so I was faster.
I can get another 1/2 a degree camber at least, and I'm going to firm up the shock compression all the way. Instructor thinks I need a lot more spring, the kw v3 I have are just too soft up front for sure, it rolled over onto the edge of the tire too much.
2008 135i
2005 mini S
PostPosted: Tue Sep 06, 2016 11:23 am
I wouldn't run RE71s on the track, you'll wind up buying a lot of tires. RS3s are a pretty popular tire for track along with ZII star specs, they both should hold up way better than a RE71. The RE71 is just way to soft for track abuse, probably especially on a FWD car.
2017 Autocross Chief of Tech
2000 E Street Miata
2015 Fiesta ST (Wife's ride)
PostPosted: Tue Sep 06, 2016 11:49 am
what about slicks? I was considering 225/45/15 maxxis RC-1 I figure I'll get more track days and to be honest tire & brake pad are the only thing that prevent me from doing one event every month
Couple guys there said the maxxis wear like iron, and they actually have a good size for my 15x8 wheels. I have 16x7 re71s on my autocross car I can use those as rain tires if needed
2008 135i
2005 mini S
PostPosted: Tue Sep 06, 2016 12:09 pm
Slicks might actually last longer than RE71s, the RE71s are really just meant to be a fast Autocross tire, I doubt they ever intended them to be run around the race track. I don't personally have experience with slicks, but I know people usually get at least a few weekends out of them, which sounds like more than you're getting from the RE71s.
2000 E Street Miata
PostPosted: Tue Sep 06, 2016 12:24 pm
I had to hold back on the 6th session and then rotate the tires. I can get another 10 sessions after I flip the tires on the wheels, so 4 days of track.
they worked really well, just the 2" of outside front edges they took a beat down, I think they were overheating just on that spot, I need to get a needle temp gauge
2008 135i
2005 mini S
PostPosted: Tue Sep 06, 2016 4:20 pm
Official Mustang Tire Corder
For a camber challenged front wheel drive car running on tracks that are particularly hard on that outside edge like NCCAR and CMP, pick a non directional tire like a BFG Rival so that you can rotate side to side as well as front to back. It's really hard to truly use up a set of tire from sidewall to sidewall running directional tires on a FWD car unless you are flipping them on the rims almost every event. That gets expensive.
IMHO, you aren't going to get much more use out of a set of slicks vs. BFG Rivals and you are going to pay more for the slicks.
And I've run the RE-71R's on my Integra at VIR and the wear isn't any worse than other tires. After two events at VIR they looked pretty good. Third event at CMP...killed them.
Stephen Westerfield
PostPosted: Tue Sep 06, 2016 4:26 pm
I'm having them flipped tomoreow, I really want a tire machine and balancer. Walmart will flip for 8$ a tire if I balance myself
2008 135i
2005 mini S
PostPosted: Tue Sep 06, 2016 5:59 pm
Famous last words. When you do, you'll gladly pay someone else to do it!
(Oh, and ignore what the manual or installer says. Bolt the balancer to the floor!)
PostPosted: Tue Sep 06, 2016 6:34 pm
got my new rims back with scratches, that is another reason I want a machine.
it's hard to justify a tire changer, but a balancer will pay for itself sooner. Ebay has changers/balancers for 1300 $ now, I have no idea how good they are
2008 135i
2005 mini S
PostPosted: Wed Sep 07, 2016 8:38 am
+1. There are a few automotive related tasks you think you want to do, but you really don't, as the aggravation factor makes it not worth your time. My list includes:
1. M&B Tires
2. Alignment
3. Window tint
PostPosted: Wed Sep 07, 2016 11:27 am
It seems to be a mixed bag with reports on them so far. Some people say they didn't hold up nearly as long while I see some people say they didn't notice much difference. FWD will be hard on any tire so I think the non-directional suggestion is a solid one.
2000 E Street Miata
PostPosted: Wed Sep 07, 2016 7:51 pm
no bfg rivals in my size, 225/45/15
still leaning towards some maxxis rc-1 they are cheap and supposed to wear like iron, supposedly they dont grip like a R7 but they wear better and the tread goes around the edge so hopefully they wear better there on FWD cars
635 $ from maxxis at least they have free shipping
2008 135i
2005 mini S
PostPosted: Wed Sep 07, 2016 8:43 pm
hmm I forgot about the NT-01 I bet those wear better too, anyone used them? they come in the size I need and they cost the same as the rc-1 so its a matter of cost per track session really, I dont care if I'm a second slower I'm still learning apex and braking zones
2008 135i
2005 mini S
PostPosted: Wed Sep 07, 2016 10:08 pm
Yeah there is.
Stephen Westerfield
