Post new topic Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: April 5-6, 2014 THSCC HPDE at VIR-N - Registration now o
PostPosted: Tue Apr 08, 2014 4:18 pm
Cash Davidson wrote:
I don't think it is that simple. The 6 uses CAN-Bus Protocol.
Yep, because prior to that running wires was hard and they never worked right. :roll: They found a solution looking for a problem. It had to be a German who had the original idea.
PostPosted: Tue Apr 08, 2014 4:23 pm
Damn technology! :soap:
HKS SLD? or a Hypertech programmer (kind of expensive...)
PostPosted: Tue Apr 08, 2014 4:37 pm
RickyBeam wrote:
Knock every other tooth off the wheel speed sensors? The ABS will still work, but it'll always see the car moving half as fast as it really is.
That's actually not a bad idea. :idea: 8)
09 Bullitt - DD
11 Fusion - Wife's DD
03 Mazda6 - Track car
00 PSD Excursion - Tow rig
61 F100 - Dad's truck
00 Cagiva - Adventure bike
00 DRZ400 - Woods bike
PostPosted: Tue Apr 08, 2014 5:02 pm
Winner-Winner! Originally developed by Bosch - a German company. :thumbsdown:
09 Bullitt - DD
PostPosted: Tue Apr 08, 2014 6:19 pm
Except that the nubs are part of the hub (rear) and axle (front). (e.g. gear teeth... machining may be recommended.)
PostPosted: Tue Apr 08, 2014 6:48 pm
Don't under-estimate the backyard engineer. :D My keen intuition nearly makes up for my complete lack of judgement. :wink:
09 Bullitt - DD
PostPosted: Tue Apr 08, 2014 8:06 pm
Updated video! Now with RaceRender overlays!
https://www.youtube.com/watch?v=eXG87aj ... e=youtu.be
PostPosted: Wed Apr 09, 2014 12:05 am
I also made this. Compares Andrew's and my best laps.
http://youtu.be/b0jgboOEoi4
PostPosted: Wed Apr 09, 2014 12:27 am
Andrew Jonell wrote:
Roger McDaniels wrote:
Yeah, Andrew, I did turn up the rear brake bias a bit too much there, my apologies. Did you notice if it was still doing it after I backed it off? I wasn't flat-spotting the rears, so I guess it wasn't too bad, but the tires were so noisy that I couldn't hear when the rears were locking up.
Nah, not that I could see. It was only that one time into T3 which is probably the one spot where it would happen (maybe T16 if you take the "I hope this works" line). Miatas lock up rears at autocross while dodging cones, but as long as the rears weren't locking before the fronts into T1/T7, you should be fine.
I was left foot braking T3, which may be why that was happening, although I'm new to mashing both right pedals, so I'm not 100% sure about that.
PostPosted: Wed Apr 09, 2014 12:36 am
A lap each of me and Ricky with data overlay, my first attempt at doing that. They are not our best laps, but we didn't get video of all of our laps due to issues with the GoPro remote.
Me: http://youtu.be/0rgaC7FKARo
Ricky: http://youtu.be/4c9CbIJwWqg
PostPosted: Fri Apr 18, 2014 2:28 pm
Further analysis: Our torque curve is relatively flat from 4500 to 5200 - meaning this is the range where the car pulls hardest.
Let's look at the speed in each gear during this 700rpm sweet spot range:
With 25.5"dia tires:
Sweet spot torque:
1st: 26-30mph
2nd: 45-52
3rd: 66-76
4th: 87-101
5th: 113-130
From the video, you can see the car accelerates well up to about 100 or so. I sense the car is not pulling as the torque is dropping off so I shift from 4th to 5th. But when I get to 5th, I am well below the sweet spot of the torque curve and the car falls flat - damn 0.733 5th gear!! :twisted:
Who's idea was it to track a family four-door? :roll:
09 Bullitt - DD
PostPosted: Fri Apr 18, 2014 3:58 pm
Sweet spot torque:
1st: 26-30mph
2nd: 45-52
3rd: 66-76
4th: 87-101
5th: 113-130
No matter what, in a non-race transmission the torque multiplication through the transmission guarantees that you will have more torque to the wheels in a lower gear at all times. I'd never think about short shifting (on a straight) unless I wanted to rest the engine.
PostPosted: Fri Apr 18, 2014 5:08 pm
Can you change the final drive? I have the same problem with my Hondas, but it's relatively simple/cheap to put an aftermarket final drive in a Honda, and it really makes the car much nicer for the track.
PostPosted: Fri Apr 18, 2014 9:38 pm
I shortish shift out of T6 and out of hogpen and it's faster (top of 3rd is close to 90mph, I shift going about 80mph). But I'm using an undersquare, FWD econobox motor that has nasty vibrations/harmonics on the higher end.
Cash needs to find a way to get a 5th gear that isn't super econo-mode, something in the .8 range should keep him riding the torque curve.
PostPosted: Sat Apr 19, 2014 11:49 am
The Australian Ford Mondeo uses the same 3.0L Duratec but with a much more track friendly gear set in a completely different tranny
Mondeo ST220 MTX75 Gear Ratios
1st 3.417
2nd 2.136
3rd 1.483
4th 1.114
5th 0.902
Final Drive 3.560
Now that's what I need! Anybody have any Aussie friends? :D
09 Bullitt - DD
