Post new topic Reply to topic  [ 190 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 13  Next
 Post subject: Re: Lemons/ChumpCar choices
PostPosted: Mon Aug 08, 2011 9:52 am
Scott Lusted wrote:
Could a motor have really good compression and still burn oil out the pipe?
Have you ever seen The General Lei run? The compression levels are right in spec and it burns about 1 quart of oil in 40 runs!
and it gets dogged hard and put away wet only to sit for months on end. and typically it starts right up. of course it is a Nissan, not a Honduh. :twisted:
PostPosted: Mon Aug 08, 2011 9:56 am
Point being the General wasn't made/designed in Germany!
PostPosted: Mon Aug 08, 2011 12:30 pm
Point being the General wasn't made/designed in Germany![/quote]
i'd be willing to bet there is some hijacked German technology and probably some German sourced parts on that fine piece of Japanese machinery. :mrgreen:
PostPosted: Mon Aug 08, 2011 12:35 pm
It is technically possible since our CEL is in fact on, and has been for about 5 years. :P
PostPosted: Mon Aug 08, 2011 12:52 pm
:twisted: you win.
PostPosted: Mon Aug 08, 2011 12:59 pm
Nothing says Fahrvergnügen like a CEL
PostPosted: Mon Aug 08, 2011 1:47 pm
No worries - I checked, and the engine is still there.
PostPosted: Mon Aug 08, 2011 11:35 pm
The way these things work, if someone were to spend a bunch of time and money on another car like the General to get it ready for Chump or Lemons, it would undoubtly self-destruct on the warm-up laps and then burn to the ground while being towed back into the paddock.
PostPosted: Thu Aug 11, 2011 7:37 pm
Update. This thing runs amazing. It is no longer burning oil and it pulls hard through the power band.
Thinking about getting a plate and drive it around for a month before going under the knife to get ready for next year!!
Man, this thing is fun to drive... Might need to find another just to use as a beater!!
-Scott
THSCC Timing & Scoring
PostPosted: Fri Aug 12, 2011 7:33 am
Pseudo cautious/nervous guy
Extremely good idea. Take it to a DE and run a couple of sessions as well. Having just wasted a Chump event as a result of a car that wasn't sorted...I wish this had been done to the car I had rented.
Tom Freeman
Team Silver Bullets '91 240SX
PostPosted: Fri Aug 12, 2011 7:46 am
while definitely a good idea, not always a fool-proof plan. Cooper's car blew up 30 minutes into the race and it had several hours of testing at CMP.
moral being, when using "the knife", cut judiciously. :wink:
PostPosted: Fri Aug 12, 2011 9:33 am
And if AT ALL POSSIBLE, run it in 2 back-to-back (zero-or-as-little-downtime as possible) sessions, try to get it driven hard for at least an hour straight no stops.
30 minutes seems to be the magic mark for head gasket, cooling, and motor issues to really start to develop.
PostPosted: Fri Aug 12, 2011 10:16 am
Thanks for all the good advice!!
Looking into the motor a little more, it appears to be the original head gasket. I'm thinking that is one part we will go ahead and take a cost hit on. I remember reading the rules where is says some things like hoses and gaskets don't make since to get used and possibly not count against the vehicle cost?
Starting a spreadsheet of things to go over on the car when we get ready to dig into it.
Mike, how much did the oil cooler you add help the temps? Found a b18c oil to water heat exchanger at a local junk yard yesterday but didn't pick it up. Wonder if it would be enough.
-Scott
PostPosted: Fri Aug 12, 2011 10:22 am
Why? Do you consider a headgasket a wear item? Unless the car has been overheated why mess with the headgasket?
I'm still amazed that Mike's held and even ran well after they changed it. Generally speaking once the car has been overheated, simply changing the gasket hardy ever works.
PostPosted: Fri Aug 12, 2011 10:36 am
-Scott
we decided that using a gauge that didn't read 45 deg too high was a better solution than adding an oil cooler. naturally we decided this after installing the cooler.
