Post new topic Reply to topic  [ 98 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
 Post subject: Re: Who's going to LeMons? 2/19-20/2011
PostPosted: Wed Feb 23, 2011 9:09 am
Hey guys, lets think this one through. That block is made to have the terminals shorted together. That means that in the phenolic block shorting strips run from one terminal to another. One of those strips has opened up. WHY????
The most likely cause is corrosion, Vibration shouldn't be a factor because everything is molded into the phenolic block, so that should be solid. If corrosion is the cause you'll see it again, cause that stuff doesn't cure itself.
My point is change it before it fails again. The cause of the problem is still there. Loosing power to the terminal is only the effect of the problem.
Another probablity is that there was a momentary overcurrent due to a short circuit on one of the wires that the terminal feeds. If it is that you can expect to see it again also. But in as much as you driven the car since the fault, its less likely that this is your problem.
Just my humble opinion.
2004 C5(415whp,390ft/lbs),
1997C5,1997Trans Am, 1986 C4,
PostPosted: Wed Feb 23, 2011 10:28 am
I'm an idea man Chuck, I get ideas, sometimes I get so many ideas that I can't even fight them off!
What if you mix the mayonnaise in the can, WITH the tunafish? Or... hold it! Chuck! I got it! Take LIVE tuna fish, and FEED 'em mayonnaise! Oh this is great.
Call Starkist!
this is jason to remind steve to SHUT UP!
PostPosted: Wed Feb 23, 2011 10:39 am
Pseudo cautious/nervous guy
More info...that I haven't though about since I bought that car.
When I bought the car, even with the key out of the ignition, the car still had power to the radio, the dash lights, etc. It was just like the car had the key in, and was sitting in the ACC position. The guy who owned the car just pulled one of the battery cable leads when he got out of the car. He had said that the car used to have an alarm in it when his uncle owned it. When they pulled the alarm out, that's when the whole electrical strangeness started.
Once we got the kill switch in the car, I don't think any of us thought about that again, as the car was usually stored with the kill switch in the off position.
Tom Freeman
Team Silver Bullets '91 240SX
PostPosted: Wed Feb 23, 2011 11:07 am
WalterHouston wrote:
Yes, that part. It is weird that just one terminal would lose power. Can I get it at the Rallycross? I don't want to replace it, but would like to have a spare just in case we have another problem. When we first started doing Lemons we brought a ton of extra parts, even a spare engine. We have slacked off and that was a mistake.
We do let Steve near tool boxes. He has Dave inside one. We don't let him near the car with tools! We are happy to let him get behind the wheel as long as he promises to shift when the big yellow light comes on and come in when the smaller red or yellow lights come on. Asking him to check the gauges didn't work, so we added water temp and oil pressure warning lights along with a shift light.
May I suggest an electric dog collar to replace the crotch strap on the 5 point harness? Just power it from the coil so it shoots 150,000v through it when the car overheats or overrevs, you could even wire it in to the ABS light so it fires when the ABS engages (or the brakes lock up).... You could completely eliminate the need for ANY warning lights.
:shock:
Come see me at the RallyX, I'll get one of those junction blocks for you. May I suggest you go ahead and replace it now, then keep the old one as a spare (maybe mark "bad" or "original" on it??)?? They're really easy to change, just 2 bolts hold it to the firewall and then the one nut that holds those 2 small wires on there- the big cable is held down with another 2 bolts.
PostPosted: Wed Feb 23, 2011 11:11 am
HMM, sounds like maybe a problem with the ignition switch, or some of the re-wiring done when the alarm was removed (???).
Ignition switch can be removed + redone with a basic toggle switch if you think that's a problem, a problem with the wiring/crimping will just take some time with a meter and a close visual of all the splices.
EDIT: did a little more research, and there is a fusible link in the small wire that comes from the + terminal of the battery to that junction block. This thing can cause the issues you describe. It's just a piece of smaller gauge wire spliced inline in that wire, back near the battery in the trunk. It's covered with heat shrink tubing. Many people who have possible problems with this thing just splice in a heavy duty fuse holder with a 60-80a fuse in place of the fusible link.
IMHO, definitely worth checking out- though it doesn't explain the electrical problems Tom mentioned, it could very well be causing the power problems you guys had this weekend.
AFAIK, that junction block at the firewall is nothing more than a mounting block for the battery cable and a terminal connector for the small wires to make contact. There is NOTHING hidden in the block that takes power from one side to the other, and there are no hidden contacts. It's a plastic block that holds the big cable, with a threaded stud that the 2 small wires attach to, that's it.
PostPosted: Wed Feb 23, 2011 1:46 pm
Thanks for the advice from Bernie and Bret. We'll work that out and move on to the half throttle miss.
Rubbin' is Racin'
PostPosted: Wed Feb 23, 2011 1:48 pm
I thought you guys drove flatout?
PostPosted: Wed Feb 23, 2011 3:40 pm
flatout, that is how i drive.
electric dog collar.. hmmmmmnmnn, i'm getting all tingley just thinking about it. :lol:
