Thanks for the help, guys....that's where I'm confused. The date of manufacture is Jan 2007, and the expiration tag clearly states "Not valid after 2011" which, if I'm reading correctly, is in line with the THSCC track/HPDE regulations stating that harnesses can't be older than 5 years. I suppose maybe I misheard/misunderstood what was said, but I remember at the time being confused when he said I'd need new harnesses in 2011. I asked him to clarify and I got the look of "How much clearer do I need to be?" as he said your harnesses will be expired for 2011.
I'll contact Mark as well.
Jan 2007 SFI Manufacture date equals Jan 2012 expiration date (as far as THSCC is concerned, unless Mark changed the spec, but I'm not aware that anything has been changed.)
So assuming the belts are in good shape (not discolored or frayed, etc. etc.) then you should be G2G for another year.
Maybe he simply meant that you'd need to buy new harnesses sometime in 2011 to be compliant for 2012?
