Marty Howard wrote:
Stacy,
I will say that when I tried both I found the Dfender seem to have better left-right-and up-down movements than the HANS, but then again, I have a longer neck.
Malia and I tried both the Hans and the Defnder (and the R3) this weekend, and for both of us this was the exact opposite. The Defender had clearance issues at the shoulder for both of us - specifically where the "extra" tethers attach on the top of the shoulder bars. Part of this could be that both of us have Zamp helmets - had they been 3/4" shorter we probably wouldn't have had much issue, but head rotation was clearly hindered as the chin of the helmet would "ride up" the shoulder bars on the Defnder. The "look down to see your harness buckles" clearance was clearly easier on the Hans as well.
The R3 seemed decent enough, and the fact that it would provide some protection even on 3-point stock belts was a nice feature, and it was reasonably comfortable.... IF you don't have breasts. The R3 was clearly NOT designed for the female anatomy, and since we were looking to find a HNR that we could share if possible, that put this one much further down the list. If I were to get one just for myself, the R3 would have gotten serious consideration.
I really wanted the Defnder to work, but we ended up buying a Hans and a second set of quick disconnect mounts for my helmet. As mentioned above, the quick-disconnect hardware for Hans is top notch, and Malia was able to get it connected first time sitting in the car without help. She was able to use it for her last session yesterday and said that it allowed good enough movement to not restrict anything but the long "out the side window" look-ahead through the exit of Carousel.
One final note - having Linda from Apex install the hardware (for free) was an excellent choice. They've done hundreds of installs, and it took them well over an hour on our helmets (evidently these Zamps are thicker shells, and use a LOT of glue between the shell and the foam, where you have to get the washer/nut wedged in behind. They said we could ship our helmets to them and they'd install, but having them done at the track between sessions was a great bonus.
