Great time! Going back to a stock powered Miata was a real eye opener regarding conservation of momentum. Didn't do so well with it on Sat until during the TT I started going thru T16 w/o braking, but I was still leaving something on the table. The TT results had me a couple of seconds behind Scott Lusted. Let me tell ya, Scott can really wheel a Miata around the track.
Sunday I continued to work on the new process thru 16 - going faster thru it & not over braking for 17 so as to blow the advantage gained. Ron Spencer called me a sissy for being a bit timid going into Stevie Wonder (the blind uphill left hander)
. So that got me pumped up a little more. By the middle of the 2nd session I was flat footed from entering the cross over to the braking zone for Roller Coaster (thanks Ron!).
Went out with Sott for the last session before the TT and showed him my line through 16 & Hog Pen. We swapped back and forth and where pretty much nose to tail the whole session.
Qualifying had me .6 seconds behind Sott for the TT. I was a little nervous about my engine because my fuel consumpion had started to double during the day. Never the less, I was going for it. I knew if I could close the gap on Scott just a little, I had a chance of taking CSP 1st away from him for that day. After running 3 hot laps in the TT I figured it wasn't going to get any better, so I called it quits. I had closed the distance on him on a couple sections of the course, but didn't think I had maintained it to where it counted - the finish line.
The end result was losing to Scott by .022 seconds. But with the 1:55.9 I started with on Sat (qualifying time), I consider a 1:51.3 a major personal improvement. Another really cool accomplishment I think that happened was consistently going through T16 while hitting the rev limiter in 3rd gear.
