Karl Shultz wrote:
Rather than an "A" side and a "B" side, there is a single line. Two-driver cars were at the front, nearest to the bus. Single driver cars made up the rest of the grid. The grid was in a single line, two cars deep. The grid is supposed to move as follows:
1. Driver #1 for car X at the top of the two-driver area goes
2. Driver #1 for car Y directly behind the first car goes
3. Repeat until through the first drivers for each two-driver car
4. Now, make your way through all of the single driver cars in the same manner, one run per car, first car in a "column," then the second, then move to the next column
5. Reach 50% of the way through the one-driver portion of grid, then...
6. Return to the top of the two-driver area
7. Release driver #2 for car X
8. Release driver #2 for car Y
9. Return to the single-driver area, and release the final 50% of the single-driver cars
Here's a real world example, using a run group of 24 entrants:
1. 6 two-driver cars
2. 12 one-driver cars, with this part of the grid cut in half, six cars per "half"
In the above-described example, 11 runs pass before the next time a two-driver car is released. With the two drivers in these cars alternating, this gives us a total of 22 runs passing between runs for driver X in any two-driver car. The number of total runs that pass between runs for the single-driver cars? 23. The interval is, essentially, identical.
Well, that explains why Mitch Moore was running up and down the grid so much during my heat. Maybe we need two grid workers, both equipped with signal flags (or air horns!) to communicate.
I am starting to see the value of AAO. (Whatever you do, don't tell Dishman I said that) At both Sanford events this year, I managed to get the jitters before my afternoon runs, and made a mess of them. So in my feeble-minded years, maybe it's best to make all of my runs in a row. Also, I don't have to reinflate my tires before the 2nd set of runs.
Of course, the advantages of 2-2 still stand:
1) If you're totally lost in the morning runs, you have an intermediate heat to figure out where you went wrong, or at least have an hour+ to complain to everybody before you go out and screw up again.
2) If you suffer a mechanical failure, or just want to make a big adjustment, you can. In my pre-ABS days, I often found myself between heats rotating tires to move a flat spot to the rear.
3) Event officers can, depending on the progress of the event, opt for 3 or (gasp) 1 run in the afternoon heats.
Final thoughts:
A) The grid scheme above is one step short of being a proper 10-step progam.
B) Michael Czeiszperger, with his excellent grasp of the issues, is a strong contender for club prez in 2011.
C) Chuck B., when he said "that's the way THSCC used to do it", was referring to his early days in the Tarheel Surry & Carriage Club.
