Donnie Barnes wrote:
Actually, prep and mod can be run pretty cheaply. Well, okay, let's classify things some, anyway.
If you are going to race your daily driver, then stock makes the most sense. Period.
But, if you're going to be going with a pretty much dedicated autocross car anyway, then I think prep and modified have their places. Some prep and mod classes are actually cheaper than MANY of the "stock" classes to be competitive nationally. Remember, too, that stock class dominant cars change every few years, generally. That's not as often the case with prep and mod cars, or even SP cars. Inexpensive classes for preparation that are above stock that come to mind are FSP, EP, GP, FM (ick), and even DM.
You do need to know more about car prep (or be willing to learn), obviously, but if that's your thing then any of those classes is long term cheaper than going racing in SS or probably even AS. Assuming you're trailering and all that anyway, that is.
Just fuel for the fire.
Don't forget CM which used to be the 3rd fastest class at Nationals if F125 isn't counted. I think Heartland Park screwed that up but Lincoln might bring it back if grip is decent. Easy to tow, rules stability, looks NEAT, long autocross component and engine life, simple to work on. Competitive (except for aging driver and a couple of new prep options that I don't have) without the need for megabuck shocks, etc. The only times I need to be UNDER the car are to clean the underside of the floor and dry sump.
FYI I plan on autocrossing it again this weekend at VMP. First autocross in 2 years for me, the car, and the tires.
