Michael Westerfield wrote:
Those are all nice for street driving (ignoring 25 cents/gallon more for premium fuel), but for autocross:
Another 25-30 rwhp - at 6200 rpm? How much do you get at 3500 or 4500? How does the torque curve look? I'm sure there's a scenario where more power would help, but not nearly as much as better shock damping or stickier tires.
Throttle response - I haven't noticed a problem. Now it's really annoying on the street, when you're coasting long enough for the computer to cut off fuel (about 2 secs), then try to blip the throttle for a downshift. Unless you give it a BIG blip, you don't get anything. Once the throttle is open (and the computer holds it open for a couple of secs after you let off the throttle), it seems to take additional inputs readily. I think it's just a matter of our courses this year being pretty open, but not all
that fast: I've only made one shift per run this year. From 1st to 2nd.
Fixed rev limiter - when Sam Strano told me about the "slap you down 500 rpm for being a bad boy" limiter on the GTs, I about cried. I ended up ordering a slightly taller tire than he runs, just to add 2 mph as the top of 2nd gear. Anyway, I haven't hit the dreaded rev limiter yet, through I have run into the traction control a few times due to wheel spin exiting turns. I keep forgetting to turn traction control off.
Other early season worries:
TPMS - My A/X wheels don't have sensors. The light hasn't come on yet.
Dire warnings in the owner's manual and shop manual about frying the car's lighting system if trailer light wiring was spliced in - I had Raleigh hitch install the hitch and wiring, just so that it wouldn't be my fault. The car's lights are doing fine, but I lost the running lights circuit to the trailer at Danville. (Since I have 2 trailers and the 5.0 is wired too, I was able to narrow it down to "something in the new Mustang") Raleigh Hitch replaced the pigtail for free last week.
My wish is that the current FS crowd stays in FS, that we prep our cars to the limit of the stock class rules, and let the battle rage.
The tuner can optimize for your settings. You can have a 87 octane tune that still gains ~10-15hp as well as 93 octane tunes. You can load them on the fly. From what I've read the throttle response is greatly improved as well. This is not all peak hp either. From what I remember you get a decent bump in midrange too.
A stock Mustang is a terrible thing. Why would I buy a car with the largest performance aftermarket?
I'll probably stick around in FS another year, but the mod bug will eventually get me.
