Marty Howard wrote:
DickRasmussen wrote:
Maybe we should go to the golf handicapping approach. Handicap the driver based on past performance.
I like that idea a lot.
Or maybe we should ditch all of our PAX classes. I like that idea a lot
Hey, I will push my lead balloon as well (and contribute to the hijacking of this thread)...
* Everyone is entered into their correct "open" class (they pick which class if they are eligible for multiple classes). All cars will be marked with open class numbers. No TIR or NOV labels on cars.
* The only exception to the above “open class for everyone” would be the PRO class. It would continue as a separate class, but with indexed results inside of the class. But this could be ditched as an exception to the rule if we wanted.
* Points, trophies, etc. is awarded based upon open class results. Basically the event runs as if there is only the "open" classes that SCCA/THSCC uses.
* There would then be three sets of additional indexed results. Regular/Open, Tire and Novice. If you are running street tires you will be automatically placed in the "TIR" results. Any class that has a PAX based upon street tires would be excluded from this index (as is today). If you call yourself a novice, you are put into the "Novice" results. Everyone else is placed into the "Regular/Open" results. No more single indexed list for everyone.
* We currently give out trophies for TIR and NOV. We can decide if we should continue to do so (I think we should). Maybe even give out trophies for the new "Regular/Open" indexed class (which we don't currently). However I know that in general there seems to be movement toward giving out less trophies.
The selling points is that open class participation will be larger (required), but TIR and NOV results will still be published and maybe even awarded. Side benefit is that the overall Indexed results will be reduced by breaking it into three parts. I personally think it is silly to lump the TIR folks into the overall indexed results as they operate at a disadvantage as they are using street tires when their respective PAX values assume "R" tires. Same deal with Novices. If they improve they will soon win and be bumped out of that set of indexed results, or will voluntarily leave the class on their own.
