Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 91 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
PostPosted: Tue Oct 02, 2007 3:51 pm
JamesFeinberg wrote:
Wes Eargle wrote:
You guys should do a rental Chevy Classic challenge.
I'd rather push a Toyota...
Scott is signed up for the event? :wink:
PostPosted: Tue Oct 02, 2007 4:03 pm
Just call me Bo
Aaron Buckley wrote:
I won't say I loved the courses, but they certainly helped us setup the car well for Nationals. Once we hit the setup on Saturday morning of the Pro (which was about a session too late to remain real competitive), we carried the exact same setup to the Tour Finale and the car drove really well during it.
To be fair, I didn't love them either but I still enjoyed driving them. They definitely favored the Miatas in my class with the amount of sweepers but that didn't stop a CRX from winning. Too bad it was the wrong CRX. :)
I know there are a lot of complaints on SCCAForums about the site and the sandy grit it is bringing up. I like the site and think for asphalt it has good grip except when the tires are dead cold. - AB
I didn't have much of a problem with sand either. The only time I even noticed it was during a practice course run on the west side when I tried not lifting in the first "wall of cones" sweeper near the top of the course. Bad idea! :lol: Needless to say, I ran a little wide during that attempted maneuver.
I thought the overall grip was just fine and even though I was expecting the car to be crazy loose as it usually is on slippery surfaces, it was nearly perfectly balanced once I put new tires on it. Despite the relatively cramped 2-course layout, I thought the site was pretty good overall.
I hope I never have to work course when the CP cars are running again but that is an entirely different issue.
PostPosted: Tue Oct 02, 2007 4:25 pm
The first time we used the Garmin for a trip, it sent us down a dirt alleyway and past a methadone clinic evidently because it was a couple hundred yards shorter distance than the main streets... :shock:
Back to the event:
On Sunday we ran the practice event which consisted of the Pro solo course with 2 offset cones added at the start. A CP car blew an engine on the right course covering it in oil, so we only ran the left course. To get a more informed opinion of the car's setup I asked Kevin Deitz (last year's CS champion) and Mark Daddio (the one true AX alien!) to each take a run with Donna as a passenger. Kevin ran first and went a full second faster than JR's best left side PS time and only .3 sec under his SS ZO6 practice time. Next Mark bested that time by .1 sec and said afterwards that with a few more runs to better familiarize himself with the car (neither had driven a GXP before) he felt he could have gone 3/4 to a full second faster yet! (When Daddio says he could go XXX faster, you can take it to the bank, he doesn't blow smoke.)
When asked about how the car handled and felt they both said "AWESOME!". Kevin said leave it alone, Mark suggested a one click front shock and 2# rear air pressure change.
With me as "ballast" Donna was able to come within .3 sec of Kevin's time, and I was .6 off her time, so we figured we were ready for Thurs.
Then the mistakes piled up!
First, Donna was made Chief of course for Tues Wed. This is second in command after Chief of Operations, and turned out to be a full time non stop 7AM-7PM job both days, as well as most of Monday. It exhausted her each day, kept her from watching runs on T,W and concentrating on coursewalks and getting her head in the right frame for driving.
Second, I found out during the practice the holes I had drilled in the FG trunk floor for shock adjustment access were technically not legal, so to avoid any possible wienie protest I found a Lowes and bought some epoxy to seal them back up.
Third, I filled the holes and changed the tires from the practice tires to the new set, as well as doing all the final car prep by myself on Wed. Usually we do this together and each has certain responsibilities during that time.
This turned out to be the biggest mistake!
Unfortunately, ASL was to run in the 2nd heat and AS in the 5th and final heat, usually open runs before Ladies, so I could not test the car and give Donna any feedback before she ran like I usually would. We had arranged for Alan Dahl to codrive with me to also give Donna feedback expecting we would run before her.
The nights were much colder after the front that had brought the showers went thru, so it was still quite cool when ASL pulled to the line Thurs AM.
Donna promptly spun on her first run on the cold tires and didn't get to build much heat in them for her second run.
Being cautious on her second run she got a clean but not fast run but the car was still loose going into turns which we again blamed on still cold tires. Her third run was looking good until the last turn before the finish where it got sideways and cost her significant time gathering it up.
When Alan went out for his first run he also promptly spun in about the same place Donna did. Once again we said "cold tires" and unfamiliarity with the car (Alan also has a GXP but it is not as developed as ours and most of his previous events had been wet.).
Fourth mistake was when I forgot to turn off the traction control on my first run resulting in a very controlled but slow run. Alan's second run was better but he carried 2 cones. His third run was clean but about a 1/2 sec off the leaders as he was being cautious, and still was complaining the car felt "twitchy" on turn in. Since Kevin nor Mark thought it was twitchy, we figured it was just the differences between his and our car that made it seem that way.
My second run was really my first and I definitely wanted to get a clean run on the board so I was extra cautious and slow. My third run was going much better as I decided to hang it out, until I came off a large right sweeper and tried to turn back for the following slalom. and the car didn't turn back but snapped around in the original direction. :shock: I didn't understand what happened.
Found out the reason Friday morning while rotating the tires, the left front hub had loosened. This is a known issue with the Soli since it does not have front spindles, the bolts attaching the hub to the aluminum upright have a tendency to loosen under the heavy loads we put on them. I normally check them every tire change, but had failed to do so when I changed the tires by myself (BIG mistake!). It must have started at the practice and got worse each of Thursday's runs. Tightening it back up made the car it's normal stable self on Friday.
Fifth mistake was Donna getting so wrapped up in the technical aspects of running the "perfect" line, she forgot to drive fast her first two runs on Friday! She finally realized it just before her third run and picked up 4 seconds but it was too little too late and only moved her up one place, one out of trophies.
Alan went out on his first run and put up the first of only a few 43's but with a cone. His second run was a clean 43, but 1/2 sec slower than his first run when he tried short shifting 3rd. He badly overdrove his 3rd run and slowed even more and picked up 2 cones as well, ending up in the 10th trophy spot.
I coned my first run, ran a clean and safe second run that was 2 sec off the pace, then coned late in my 3rd run, giving up after that and finished 53 out of 60.
Our biggest "highlite" if we look for a silver lining is that our car was the second highest finishing GXP in AS and ASL with the quickest taking 2nd in AS and 1st in ASL (beating the GM performance group entry in open).
Not too bad for a car that had basically one month's development time!
To paraphrase a popular quote: The Solstice GXP's "death" has been highly exaggerated! :wink:
PostPosted: Tue Oct 02, 2007 4:51 pm
Just call me Bo
I wouldn't read too much into the practice times compared to the Finale even with the kink at the start. Everybody I talked to went *much* faster during practice than they did during the Finale on the left side. You could try to attribute that to the pressure being off but when somebody like Rob Carpenter goes nearly 2 seconds faster, you know the surface (or at least the "line") picked up a ton of grip.
I personally went over 2 seconds faster and beat our class leader's times by over a second. While I was on new tires versus the crap I was running in the Finale, there is no way they were *that* much faster.
PostPosted: Tue Oct 02, 2007 5:36 pm
Plus the times he's comparing to were Jonathan's times in his FIRST session of the Pro, since after that our car was broken. I'm quite certain Jonathan would have gone a lot faster if given the opportunity, if for no other reason than rubber getting put down.
PostPosted: Tue Oct 02, 2007 11:09 pm
Donnie, there is a better explanation here - AB
PostPosted: Wed Oct 03, 2007 12:15 pm
Stalker
Wow. This is a shocking news from the "no, I'm not the driver, I'm just the pitcrew...SHE'S the driver!" world. Shame, shame, pitcrew. :lol:
That dope Crossfire is actually mine.
PostPosted: Wed Oct 03, 2007 12:18 pm
Stalker
Now that's entertainment. :party:
"Stated goal" in the sig. Love it! :cheer:
PostPosted: Wed Oct 03, 2007 4:08 pm
It's "interesting" that I refrained from commenting on anyone else's post, but y'all find it necessary to nitpick and flame anything I say and are still stalking Donna and I all over the internet. GROW UP and get a life or at least get out of ours!
PostPosted: Wed Oct 03, 2007 4:29 pm
Stalking? I guess I didn't realize you were hanging out with Al Gore when he created the internet. :oops: I'll remember to never, ever visit a car site again that you might actually post on.... I guess that leaves me with only a few. - AB
PostPosted: Wed Oct 03, 2007 4:39 pm
It's funny how much of what "we" have said here has been echoed publicly by other people almost verbatim (and none of those folks had any knowledge of what we said here, AFAIK), yet you don't accuse those folks of stalking you. I mean both Nick Flynn and Jason Isley have given you crap for some of the exact things we gave you crap for, yet we're stalking you? Ever consider that you say stupid things and we (and a lot of other people) call you on it? Oh, no, I forgot...Jason wasn't stalking you, he was just hanging out in a forum he didn't "belong" in or some such nonsense because he doesn't own a Solstice.
And perhaps we find out about this stuff on the other forums because people who *do* have an interest in those forums send us links because they are laughing at you, too? I don't think I've ever willingly gone to the Solstice forum except for that case, in fact. But I've been there a lot...
PostPosted: Wed Oct 03, 2007 4:47 pm
IBTL
PostPosted: Wed Oct 03, 2007 5:07 pm
Just call me Bo
I don't know about the rest of you punks but I *am* stalking! Heck, without stalking, I would have never met my last couple of girlfriends!!! :D
Chuck, I have no idea if you were referring to me in your "nitpick" comment but I'll certainly stand by what I wrote. I understand your point about generally being outrun by Aaron, GH and myself in RAW time on most courses. And the fact that you weren't (or were at least close) at the Finale gives some indication about the nature of the course(s) but it just sounds funky. You are in an *AS* car-- you're *supposed* to outrun us on RAW time. Never mind the fact that I was struggling on what turned out to be a bad set of tires. Pointing to RAW times as evidence that the courses were inherently flawed as data points in a vacuum doesn't strengthen your argument, IMHO. As for outrunning Aaron, I'll be the first to admit it, you just plain worked him!!! :lol: <-- See, equal opportunity picker!
As far as my comments about the practice course, I was lending some perspective to those that weren't there. And if you didn't talk to a lot of people out there, you might not have been aware that a ton of people picked up time despite the kink at the start. And a bunch of those people weren't picking up time just because they had more cracks at the course. If you were aware that plenty of people picked up tons of time, conveniently leaving out that detail doesn't help much of anything either.
PostPosted: Wed Oct 03, 2007 5:49 pm
Stalker
It's "interesting" that you choose to post details of your life on the Internet but expect people to "get out of" it.
You'd be long forgotten if you just stopped posting and spent more time doing whatever you do in that closetful of ill-fitting jackets.
PostPosted: Wed Oct 03, 2007 5:54 pm
Stalker
:word:
