Karl Shultz wrote:
I'm also unclear whether or not the R1 is a "track" tire, an "autocross" tire, or a "both" tire. Since I'm only autocrossing the car, I tend towards a tire that is an "autocross" tire first and foremost. If the R1 turns into a "both" tire, I suppose I could buy a third set of wheels, and run locals on the R1s, and save the A6s for Pros and Nationals...but now we're talking about so much back end cost that I may as well just stick with the A6s.
Right?
Chuck, thanks again for being willing to try the bleeding edge stuff and sharing your experiences. Hope you've got them at Danville next month, since I think you've run A6s on that car at that site and can maybe do a reasonable comparison between the two...
Re A6s -- I think (fingers crossed) that the tread life of the R1 will
greatly exceed that of the A6. I've not had good luck with A6s as you guys know plus I simply do not like their turn-in characteristics on the 330i -- they feel lazy, need higher slip angles for a given level of grip compared to other tires I've recently driven on the track and autox on both the 330 and M5. Clearly that is just a driver issue on my part since A6s sit at the top of the autocross mantle; however, couple it with the very rapid wear rate and the cost in 18" sizes, and it quickly begins to look unappealing.
I've not driven the A6 at Danville (just NCAC last summer, Sanford and Laurinburg), so the only comparison we can make other than my subjective comments will be PAX placement versus other drivers I guess.
That said, at Laurinburg I kept screwing up the far right corner (looking down course from start) where you turn to come back toward the bus. It kept sucking me in and I kept falling for it carrying WAY too much speed -- you would think after one or two runs, I would have solved that issue, but no. Cones, one DNF there, etc..sigh. On my last run I STILL overcooked it but just not quite as bad so I made the cone I had been killing, but I still lost some serious time there having to way overslow the car to not hit “my” cone (not to mention I started the run with major cord showing on the LF
). I was 1 second faster in my 3rd run but just tapped the cone there (got a 69.543). Hence my fastest clean run was a 70.575 while I'm pretty sure I could have run the mid 69's if I could have fixed that one section (I hear Tim and Jr in my ear as I type this, lol).
I'm only going over all of this so that we'll have a better idea of PAX comparisons at Danville. I PAX'd 9th at L'burg, and if I could have captured that 69.543, I would have PAX'd 5th. Granted Danville is a totally different course, different drivers might show up, some won't be there who were at L'burg, etc, etc.
Finally, if I’m just better able to jive with the R1 and make it work for me, that still really doesn’t tell us how it compares with the A6. I like Donnie’s idea…I’ll supply the car with mounted R1s, and I have two still good A6s along with two extra front rims. Now all we need are two more 245/35-18 A6s and two rear 8.5x18 rear rims for the 330 and of course a venue plus a datalogger. The three of us can shake out the two tire sets on my car…
