Aaron Buckley wrote:
We ran 10 runs at Sanford and 4 practice runs at Huntsville (medium grip asphalt). On my first run of the event, the driver front started to cord the outside edge. Yes, on the 15th run.
Bryan drove his first and the passenger front began to cord. The cord caused the car to push on our 2nd runs and our third runs had the steel belts coming undone. Not fun.
Well, I'm back again with the same issue using the two new A6s Hoosier sent me late last summer to replace the others that corded. We ran the brand new ones up front on the 330i zhp starting at 52 psi as directed by Hoosier. This year we have a large front sway bar on the car, toe is zero, camber full max which is around -1.2 or so.
After a total of 8 runs at Sanford, I flipped the fronts on the rims this past Saturday (thinking ahead about how hard L'burg is on tires). So starting on Sunday we had perfect outside edges on the fronts with the little tickys showing even. By the end of run number 8, cords were starting to show on that outside 45 degree angle thing the A6 tread face makes (i.e. just like Aaron's picture), and by the end of run 10, the tire was totally wasted.
I'm done with Hoosiers...have some BFG R1's in 265/35-18 on the way. These might not be the best for autocross, but we'll hopefully get some decent wear out of them. I can't find anyone around who has tried these for autocross, so I'm the guinea pig.
Back to the A6 for moment…that “outside 45 degree angle thing” I mentioned up above refers to how these tires wear on their shoulder. After the morning runs at Laurinburg, I noticed what looked like a 45-degree ramp angle wearing on the shoulder (as opposed to a nice rounded wear pattern you typically see on tires). You could actually see the main tread face belt/tread thickness, then the 45-degree angle wear down to the sidewall support structure. I’ve never seen something like this on any other tire over a zillion years of tracking and autocrossing. It’s like the tread compound is too thin and not properly supported in this section of the main tread face to sidewall junction. If you look at Aaron's picture, you can see the semi-depression the tread makes along the shoulder where the cords appear.
I can post pics later if anyone is interested.
Chuck
