Aaron Buckley wrote:
We ran 10 runs at Sanford and 4 practice runs at Huntsville (medium grip asphalt). On my first run of the event, the driver front started to cord the outside edge. Yes, on the 15th run.
Wow, does this sound familiar:
http://thscc.com/phpBB/viewtopic.php?t=5287
Since then I added a 27mm front bar and set it to full stiff (a bit over 1" less moment arm than stock, stock diameter was 24mm). I have the front camber max'd at -1.2 degrees, toe at zero. The camber curve with compression is reasonable (for a strut suspension) on the 330i I think; caster is about 6 degrees at static height.
Jeff probably won't really have much to say other than "raise the air pressure", but perhaps you can get some help from him. Is it possible that you are seeing major bushing deflection at full lateral load or something similar? Also, dang, I had no idea you have a ~500lb weight advantage over the 330i zhp!
I think I'm going to try to find someone to mount/air up the V710 245/35 on my 8" and 8.5" rims again before the DC event. My other option is to run 285/30-18 all around since from the measurements I made, I "think" these will just fit on the car. If I go that route, I'll stick with the A6 probably in order to be more able to mount/air up the tires.
Chuck
