So what is wrong with the course map?
The answer is a little bit of everything. In this case, while I had the DL-1 mounted reasonably solid, it still had a *touch* of wiggle room due to the tape. It did have a very minimal effect on the accelerometer data collected but I’d consider it negligible for our purposes. In general, I’d consider that data “the gospel”.
It seems that the overall perception of these tools is that they can instantly provide you with useful feedback. While that is true to some degree, they certainly have their limitations with regard to GPS capabilities and it usually isn’t apparent until you really start playing with one. The first limitation is simply one of sampling rate. Most (all?) of the sub-$1000 products only produce GPS data 5 times a second which while useful for general mapping, they can easily miss some course subtleties. The current generation of the DL-1 samples GPS data at 10Hz but that still isn’t enough to catch everything either. The bottom line? The course can wind up being a bunch of “half-truths”. It goes mostly where you think it does but you need to watch out for really quick inputs that may throw things off. Well, that’s not so bad, is it? Not so much. It is still very useful but that leads us to GPS “gotcha” #2.
And this is a biggie! The GPS data we are collecting is only accurate to a few meters! Wait, a few meters? Yep! Think about how big that is for a second in auto-x terms. One meter is roughly 3.3 feet so that means that if a “few” is defined as 3, that is nearly 10 feet! Most of the manufactures claim accuracy to 2 meters under what I would have to imagine would be very good conditions but that would still be only good to roughly 7 feet. In a sport where we are clipping the bases of cones, it’s clear the course maps aren’t going to help us pick a perfect line or figure out if we were even close to any cones. If you listen closely, you can probably hear the sound of bubbles bursting all over the Triangle. This sucks, right?
Wait, it gets worse! Not only is the GPS data not really that accurate but it “drifts” while you are sitting still! I’ve observed a much as a 15 foot “drift” while sitting stationary during testing. Cool, huh? Even cooler is the fact that the GPS still drifts while you are moving so your line is technically slowly wobbling all over the place as you drive. It’s kinda like giving a drunk a compass and a measuring tape and then asking him to survey a race track! Don’t believe me? Take a look at this next image.
Zoomed-in image of the area around the start line:
The green line is my first run of the day, the red line is my third run of the day and the black line is my last run of the day. I was *very* careful about lining up in the same place each time and yet it looks like I was all over the place. According to the scale in the upper left corner of the image, the first and last runs are nearly 8 meters apart! That’s more drift action than the last FnF movie!!!
OK, so this is totally useless, right? I mean, the course has to be a bunch of damn lies at this point, doesn’t it? Well, it turns out that through the miracle of cloning, it’s actually not that baaaaaad! Either that, or I’m getting ready to pull the wool over your eyes!
Next installment: Flocking to the truth.
